The problem with db_create_read_log() is that it is not yet initialized when PINI=YES runs (resulting in a NULL pointer access crash). At least not in softIoc, in softIocPVA it works!
Diff comments:
> diff --git a/modules/database/src/ioc/db/dbDbLink.c b/modules/database/src/ioc/db/dbDbLink.c
> index f2cb0c5..ff77c3f 100644
> --- a/modules/database/src/ioc/db/dbDbLink.c
> +++ b/modules/database/src/ioc/db/dbDbLink.c
> @@ -160,30 +165,52 @@ static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
> long *pnRequest)
> struct pv_link *ppv_link = &plink->value.pv_link;
> - DBADDR *paddr = ppv_link->pvt;
> + dbChannel *chan = linkChannel(plink);
> + DBADDR *paddr = &chan->addr;
> dbCommon *precord = plink->precord;
> long status;
> /* scan passive records if link is process passive */
> if (ppv_link->pvlMask & pvlOptPP) {
> - status = dbScanPassive(precord, paddr->precord);
> + status = dbScanPassive(precord, dbChannelRecord(chan));
> if (status)
> return status;
> - if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
> - status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
> + /* If filters are involved in a read, create field log and run filters */
> + if (ellCount(&chan->filters)) {
> + long options = 0;
> + db_field_log fl = {};
> + fl.ctx = dbfl_context_read;
> + fl.type = dbfl_type_rec;
> + /* For the moment, empty arrays are not supported by EPICS */
> + if (dbChannelFinalElements(chan) > 0)
> + dbChannelRunPreChain(chan, &fl);
> + dbChannelRunPostChain(chan, &fl);
I had that first but was running into other problems. So I changed it to a local variable after consulting Andrew.
I will change it back to a dynamically allocated object.
> + status = dbChannelGet(chan, dbrType, pbuffer, &options, pnRequest, &fl);
> + if (!status && pnRequest && *pnRequest <= 0)
> + status = S_db_badField;
> + } else {
> + if (status) {
> + recGblSetSevr(precord, LINK_ALARM, UDF_ALARM);
> + } else if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
> + status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
> } else {
> - unsigned short dbfType = paddr->field_type;
> + unsigned short dbfType = dbChannelFinalFieldType(chan);
> if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
> return S_db_badDbrtype;
> - if (paddr->no_elements == 1 && (!pnRequest || *pnRequest == 1)
> - && paddr->special != SPC_DBADDR
> - && paddr->special != SPC_ATTRIBUTE) {
> + if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
> + && dbChannelSpecial(chan) != SPC_DBADDR
> + && dbChannelSpecial(chan) != SPC_ATTRIBUTE) {
> ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
> } else {
> ppv_link->getCvt = NULL;
> status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
[Merge] ~dirk.zimoch/epics-base:emptyArrayCrashFix into epics-base:3.15 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
