2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Wed, 12 Feb 2020 16:58:23 -0000
Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0.
Commit message:
Make filters available for database links
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0.
diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
index 19f6038..905cffe 100644
--- a/modules/database/src/ioc/db/dbAccess.c
+++ b/modules/database/src/ioc/db/dbAccess.c
@@ -1023,7 +1023,7 @@ static long dbPutFieldLink(DBADDR *paddr,
     short dbrType, const void *pbuffer, long nRequest)
     dbLinkInfo  link_info;
-    DBADDR      *pdbaddr = NULL;
+    dbChannel   *chan = NULL;
     dbCommon    *precord = paddr->precord;
     dbCommon    *lockrecs[2];
     dbLocker    locker;
@@ -1061,16 +1061,11 @@ static long dbPutFieldLink(DBADDR *paddr,
     if (link_info.ltype == PV_LINK &&
         (link_info.modifiers & (pvlOptCA | pvlOptCP | pvlOptCPP)) == 0) {
-        DBADDR tempaddr;
-        if (dbNameToAddr(link_info.target, &tempaddr)==0) {
-            /* This will become a DB link. */
-            pdbaddr = malloc(sizeof(*pdbaddr));
-            if (!pdbaddr) {
-                status = S_db_noMemory;
-                goto cleanup;
-            *pdbaddr = tempaddr; /* struct copy */
+        chan = dbChannelCreate(link_info.target);
+        if (chan && dbChannelOpen(chan) != 0) {
+            errlogPrintf("ERROR: dbPutFieldLink %s.%s=%s: dbChannelOpen() failed\n",
+                precord->name, pfldDes->name, link_info.target);
+            goto cleanup;
@@ -1079,7 +1074,7 @@ static long dbPutFieldLink(DBADDR *paddr,
     memset(&locker, 0, sizeof(locker));
     lockrecs[0] = precord;
-    lockrecs[1] = pdbaddr ? pdbaddr->precord : NULL;
+    lockrecs[1] = chan ? dbChannelRecord(chan) : NULL;
     dbLockerPrepare(&locker, lockrecs, 2);
     dbScanLockMany(&locker);
@@ -1167,7 +1162,8 @@ static long dbPutFieldLink(DBADDR *paddr,
     case PV_LINK:
     case CONSTANT:
     case JSON_LINK:
-        dbAddLink(&locker, plink, pfldDes->field_type, pdbaddr);
+        dbAddLink(&locker, plink, pfldDes->field_type, chan);
+        chan = NULL; /* don't clean it up */
         break;
     case DB_LINK:
@@ -1197,6 +1193,8 @@ unlock:
     dbScanUnlockMany(&locker);
     dbLockerFinalize(&locker);
 cleanup:
+    if (chan)
+        dbChannelDelete(chan);
     free(link_info.target);
     return status;
diff --git a/modules/database/src/ioc/db/dbDbLink.c b/modules/database/src/ioc/db/dbDbLink.c
index f2cb0c5..4d38185 100644
--- a/modules/database/src/ioc/db/dbDbLink.c
+++ b/modules/database/src/ioc/db/dbDbLink.c
@@ -60,6 +60,7 @@
 #include "dbConvertFast.h"
 #include "dbConvert.h"
 #include "db_field_log.h"
+#include "db_access_routines.h"
 #include "dbFldTypes.h"
 #include "dbLink.h"
 #include "dbLockPvt.h"
@@ -73,7 +74,7 @@
 #include "recSup.h"
 #include "special.h"
 #include "dbDbLink.h"
+#include "dbChannel.h"
 /***************************** Database Links *****************************/
@@ -82,45 +83,63 @@ static lset dbDb_lset;
 static long processTarget(dbCommon *psrc, dbCommon *pdst);
+#define linkChannel(plink) ((dbChannel *) (plink)->value.pv_link.pvt)
 long dbDbInitLink(struct link *plink, short dbfType)
-    DBADDR dbaddr;
     long status;
-    DBADDR *pdbAddr;
+    dbChannel *chan;
+    dbCommon *precord;
-    status = dbNameToAddr(plink->value.pv_link.pvname, &dbaddr);
+    chan = dbChannelCreate(plink->value.pv_link.pvname);
+    if (!chan)
+        return S_db_notFound;
+    status = dbChannelOpen(chan);
     if (status)
         return status;
+    precord = dbChannelRecord(chan);
+    if (dbChannelFinalElements(chan) < 1) {
+        errlogPrintf("Warning: %s.%s=%s has %ld elements. This will not work.\n",
+            plink->precord->name, dbLinkFieldName(plink),
+            dbChannelName(chan), dbChannelFinalElements(chan));
     plink->lset = &dbDb_lset;
     plink->type = DB_LINK;
-    pdbAddr = dbCalloc(1, sizeof(struct dbAddr));
-    *pdbAddr = dbaddr; /* structure copy */
-    plink->value.pv_link.pvt = pdbAddr;
-    ellAdd(&dbaddr.precord->bklnk, &plink->value.pv_link.backlinknode);
+    plink->value.pv_link.pvt = chan;
+    ellAdd(&precord->bklnk, &plink->value.pv_link.backlinknode);
     /* merging into the same lockset is deferred to the caller.
      * cf. initPVLinks()
-    dbLockSetMerge(NULL, plink->precord, dbaddr.precord);
-    assert(plink->precord->lset->plockSet == dbaddr.precord->lset->plockSet);
+    dbLockSetMerge(NULL, plink->precord, precord);
+    assert(plink->precord->lset->plockSet == precord->lset->plockSet);
     return 0;
 void dbDbAddLink(struct dbLocker *locker, struct link *plink, short dbfType,
-    DBADDR *ptarget)
+    dbChannel *chan)
-    plink->value.pv_link.pvt = ptarget;
-    ellAdd(&ptarget->precord->bklnk, &plink->value.pv_link.backlinknode);
+    ellAdd(&dbChannelRecord(chan)->bklnk, &plink->value.pv_link.backlinknode);
     /* target record is already locked in dbPutFieldLink() */
-    dbLockSetMerge(locker, plink->precord, ptarget->precord);
+    dbLockSetMerge(locker, plink->precord, dbChannelRecord(chan));
 static void dbDbRemoveLink(struct dbLocker *locker, struct link *plink)
-    DBADDR *pdbAddr = (DBADDR *) plink->value.pv_link.pvt;
+    dbChannel *chan = linkChannel(plink);
+    dbCommon *precord = dbChannelRecord(chan);
     plink->type = PV_LINK;
@@ -130,10 +149,10 @@ static void dbDbRemoveLink(struct dbLocker *locker, struct link *plink)
         plink->value.pv_link.getCvt = 0;
         plink->value.pv_link.pvlMask = 0;
         plink->value.pv_link.lastGetdbrType = 0;
-        ellDelete(&pdbAddr->precord->bklnk, &plink->value.pv_link.backlinknode);
-        dbLockSetSplit(locker, plink->precord, pdbAddr->precord);
+        ellDelete(&precord->bklnk, &plink->value.pv_link.backlinknode);
+        dbLockSetSplit(locker, plink->precord, precord);
-    free(pdbAddr);
 static int dbDbIsConnected(const struct link *plink)
@@ -143,16 +162,14 @@ static int dbDbIsConnected(const struct link *plink)
 static int dbDbGetDBFtype(const struct link *plink)
-    DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
-    return paddr->field_type;
+    return dbChannelFinalFieldType(chan);
 static long dbDbGetElements(const struct link *plink, long *nelements)
-    *nelements = paddr->no_elements;
+    *nelements = dbChannelFinalElements(chan);
     return 0;
@@ -160,30 +177,48 @@ static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
         long *pnRequest)
     struct pv_link *ppv_link = &plink->value.pv_link;
-    DBADDR *paddr = ppv_link->pvt;
+    DBADDR *paddr = &chan->addr;
     dbCommon *precord = plink->precord;
     long status;
     /* scan passive records if link is process passive  */
     if (ppv_link->pvlMask & pvlOptPP) {
-        status = dbScanPassive(precord, paddr->precord);
+        status = dbScanPassive(precord, dbChannelRecord(chan));
         if (status)
             return status;
-    if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
-        status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
+    /* If filters are involved in a read, create field log and run filters */
+    if (ellCount(&chan->filters)) {
+        db_field_log *pfl;
+        long options = 0;
+            recGblSetSevr(precord, LINK_ALARM, UDF_ALARM);
+            return S_db_badField;
+        pfl = db_create_read_log(chan);
+        if (pfl) {
+            pfl = dbChannelRunPreChain(chan, pfl);
+            pfl = dbChannelRunPostChain(chan, pfl);
+            status = dbChannelGet(chan, dbrType, pbuffer, &options, pnRequest, pfl);
+            db_delete_field_log(pfl);
+    } else if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
+        status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
     } else {
-        unsigned short dbfType = paddr->field_type;
+        unsigned short dbfType = dbChannelFinalFieldType(chan);
         if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
             return S_db_badDbrtype;
-        if (paddr->no_elements == 1 && (!pnRequest || *pnRequest == 1)
-                && paddr->special != SPC_DBADDR
-                && paddr->special != SPC_ATTRIBUTE) {
+        if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
+                && dbChannelSpecial(chan) != SPC_DBADDR
+                && dbChannelSpecial(chan) != SPC_ATTRIBUTE) {
             ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
         } else {
             ppv_link->getCvt = NULL;
             status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
@@ -191,16 +226,18 @@ static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
         ppv_link->lastGetdbrType = dbrType;
-    if (!status && precord != paddr->precord)
+    if (!status && precord != dbChannelRecord(chan))
         recGblInheritSevr(plink->value.pv_link.pvlMask & pvlOptMsMode,
-            plink->precord, paddr->precord->stat, paddr->precord->sevr);
+            plink->precord,
+            dbChannelRecord(chan)->stat, dbChannelRecord(chan)->sevr);
     return status;
 static long dbDbGetControlLimits(const struct link *plink, double *low,
         double *high)
     struct buffer {
         DBRctrlDouble
         double value;
@@ -221,7 +258,8 @@ static long dbDbGetControlLimits(const struct link *plink, double *low,
 static long dbDbGetGraphicLimits(const struct link *plink, double *low,
         double *high)
     struct buffer {
         DBRgrDouble
         double value;
@@ -242,7 +280,8 @@ static long dbDbGetGraphicLimits(const struct link *plink, double *low,
 static long dbDbGetAlarmLimits(const struct link *plink, double *lolo,
         double *low, double *high, double *hihi)
     struct buffer {
         DBRalDouble
         double value;
@@ -264,7 +303,8 @@ static long dbDbGetAlarmLimits(const struct link *plink, double *lolo,
 static long dbDbGetPrecision(const struct link *plink, short *precision)
     struct buffer {
         DBRprecision
         double value;
@@ -283,7 +323,8 @@ static long dbDbGetPrecision(const struct link *plink, short *precision)
 static long dbDbGetUnits(const struct link *plink, char *units, int unitsSize)
     struct buffer {
         DBRunits
         double value;
@@ -303,20 +344,20 @@ static long dbDbGetUnits(const struct link *plink, char *units, int unitsSize)
 static long dbDbGetAlarm(const struct link *plink, epicsEnum16 *status,
         epicsEnum16 *severity)
     if (status)
-        *status = paddr->precord->stat;
+        *status = precord->stat;
     if (severity)
-        *severity = paddr->precord->sevr;
+        *severity = precord->sevr;
     return 0;
 static long dbDbGetTimeStamp(const struct link *plink, epicsTimeStamp *pstamp)
-    *pstamp = paddr->precord->time;
+    *pstamp = precord->time;
     return 0;
@@ -324,9 +365,10 @@ static long dbDbPutValue(struct link *plink, short dbrType,
     struct dbCommon *psrce = plink->precord;
-    DBADDR *paddr = (DBADDR *) ppv_link->pvt;
-    dbCommon *pdest = paddr->precord;
+    dbCommon *pdest = dbChannelRecord(chan);
     long status = dbPut(paddr, dbrType, pbuffer, nRequest);
     recGblInheritSevr(ppv_link->pvlMask & pvlOptMsMode, pdest, psrce->nsta,
@@ -334,7 +376,7 @@ static long dbDbPutValue(struct link *plink, short dbrType,
     if (status)
         return status;
-    if (paddr->pfield == (void *) &pdest->proc ||
+    if (dbChannelField(chan) == (void *) &pdest->proc ||
         (ppv_link->pvlMask & pvlOptPP && pdest->scan == 0)) {
         status = processTarget(psrce, pdest);
@@ -345,9 +387,8 @@ static long dbDbPutValue(struct link *plink, short dbrType,
 static void dbDbScanFwdLink(struct link *plink)
-    dbAddr *paddr = (dbAddr *) plink->value.pv_link.pvt;
-    dbScanPassive(precord, paddr->precord);
+    dbScanPassive(precord, dbChannelRecord(chan));
 static long doLocked(struct link *plink, dbLinkUserCallback rtn, void *priv)
diff --git a/modules/database/src/ioc/db/dbDbLink.h b/modules/database/src/ioc/db/dbDbLink.h
index c367720..27972d8 100644
--- a/modules/database/src/ioc/db/dbDbLink.h
+++ b/modules/database/src/ioc/db/dbDbLink.h
@@ -26,7 +26,7 @@ struct dbLocker;
 epicsShareFunc long dbDbInitLink(struct link *plink, short dbfType);
 epicsShareFunc void dbDbAddLink(struct dbLocker *locker, struct link *plink,
-    short dbfType, DBADDR *ptarget);
+    short dbfType, dbChannel *ptarget);
 #ifdef __cplusplus
diff --git a/modules/database/src/ioc/db/dbLink.c b/modules/database/src/ioc/db/dbLink.c
index 7c37058..aa72dc8 100644
--- a/modules/database/src/ioc/db/dbLink.c
+++ b/modules/database/src/ioc/db/dbLink.c
@@ -143,7 +143,7 @@ void dbInitLink(struct link *plink, short dbfType)
 void dbAddLink(struct dbLocker *locker, struct link *plink, short dbfType,
-    DBADDR *ptarget)
+    dbChannel *ptarget)
     struct dbCommon *precord = plink->precord;
diff --git a/modules/database/src/ioc/db/dbLink.h b/modules/database/src/ioc/db/dbLink.h
index 94e1f32..4255a56 100644
--- a/modules/database/src/ioc/db/dbLink.h
+++ b/modules/database/src/ioc/db/dbLink.h
@@ -20,6 +20,7 @@
 #include "epicsTypes.h"
 #include "epicsTime.h"
 #include "dbAddr.h"
 #ifdef __cplusplus
 extern "C" {
@@ -368,7 +369,7 @@ epicsShareFunc const char * dbLinkFieldName(const struct link *plink);
 epicsShareFunc void dbInitLink(struct link *plink, short dbfType);
 epicsShareFunc void dbAddLink(struct dbLocker *locker, struct link *plink,
 epicsShareFunc void dbLinkOpen(struct link *plink);
 epicsShareFunc void dbRemoveLink(struct dbLocker *locker, struct link *plink);
diff --git a/modules/database/src/ioc/db/dbLock.c b/modules/database/src/ioc/db/dbLock.c
index 8df755b..19cb1c0 100644
--- a/modules/database/src/ioc/db/dbLock.c
+++ b/modules/database/src/ioc/db/dbLock.c
@@ -743,14 +743,14 @@ void dbLockSetSplit(dbLocker *locker, dbCommon *pfirst, dbCommon *psecond)
             for(i=0; i<rtype->no_links; i++) {
                 dbFldDes *pdesc = rtype->papFldDes[rtype->link_ind[i]];
                 DBLINK *plink = (DBLINK*)((char*)prec + pdesc->offset);
-                DBADDR *ptarget;
+                dbChannel *chan;
                 lockRecord *lr;
                 if(plink->type!=DB_LINK)
                     continue;
-                ptarget = plink->value.pv_link.pvt;
-                lr = ptarget->precord->lset;
+                chan = plink->value.pv_link.pvt;
+                lr = dbChannelRecord(chan)->lset;
                 assert(lr);
                 if(lr->precord==pfirst) {
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
[Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 noreply--- via Core-talk
Prev: Build failed: epics-base-test base-7.0-33 AppVeyor via Core-talk
Next: Build failed: epics-base base-reuseport-395 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 18 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
