Review: Needs Fixing
Also, this MR changes the behavior of the following db
to leave dst with a link alarm. Currently there is no
alarm, which I believe is correct. Zero length DB links
have long worked. See my diff comment on the conditional
in question.
record(aai, "src") {
field(FTVL, "DOUBLE")
field(NELM, "10")
field(FLNK, "dst")
field(PINI, "YES")
record(aai, "dst") {
field(NELM, "10")
field(INP , "src NPP")
Diff comments:
> diff --git a/modules/database/src/ioc/db/dbDbLink.c b/modules/database/src/ioc/db/dbDbLink.c
> index f2cb0c5..dbf7cae 100644
> --- a/modules/database/src/ioc/db/dbDbLink.c
> +++ b/modules/database/src/ioc/db/dbDbLink.c
> @@ -160,47 +165,78 @@ static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
> long *pnRequest)
> struct pv_link *ppv_link = &plink->value.pv_link;
> - DBADDR *paddr = ppv_link->pvt;
> + dbChannel *chan = linkChannel(plink);
> + DBADDR *paddr = &chan->addr;
> dbCommon *precord = plink->precord;
> + db_field_log *pfl = NULL;
> long status;
> /* scan passive records if link is process passive */
> if (ppv_link->pvlMask & pvlOptPP) {
> - status = dbScanPassive(precord, paddr->precord);
> + status = dbScanPassive(precord, dbChannelRecord(chan));
> if (status)
> return status;
> - if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
> - status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
> - } else {
> - unsigned short dbfType = paddr->field_type;
> + if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType)
> + /* shortcut: scalar with known conversion, no filter */
> + status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
> + else if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
> + && dbChannelSpecial(chan) != SPC_DBADDR
> + && dbChannelSpecial(chan) != SPC_ATTRIBUTE
> + && ellCount(&chan->filters) == 0)
> + /* simple scalar: set up shortcut */
> + unsigned short dbfType = dbChannelFinalFieldType(chan);
> if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
> return S_db_badDbrtype;
> - if (paddr->no_elements == 1 && (!pnRequest || *pnRequest == 1)
> - && paddr->special != SPC_DBADDR
> - && paddr->special != SPC_ATTRIBUTE) {
> - ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
> - } else {
> - ppv_link->getCvt = NULL;
> - status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
> + ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
> ppv_link->lastGetdbrType = dbrType;
> + else
> + /* filter, array, or special */
> + ppv_link->getCvt = NULL;
> + if (ellCount(&chan->filters)) {
> + /* If filters are involved in a read, create field log and run filters */
> + pfl = db_create_read_log(chan);
> + if (!pfl)
> + return S_db_noMemory;
> + pfl = dbChannelRunPreChain(chan, pfl);
> + pfl = dbChannelRunPostChain(chan, pfl);
> + status = dbChannelGet(chan, dbrType, pbuffer, NULL, pnRequest, pfl);
> + if (pfl)
> + db_delete_field_log(pfl);
> + if (status)
> + return status;
> + if (pnRequest && *pnRequest <= 0)
> + return S_db_emptyArray;
I don't think this should be an error as the caller can see that zero elements are being returned.
> - if (!status && precord != paddr->precord)
> + if (!status && precord != dbChannelRecord(chan))
> recGblInheritSevr(plink->value.pv_link.pvlMask & pvlOptMsMode,
> - plink->precord, paddr->precord->stat, paddr->precord->sevr);
> + plink->precord,
> + dbChannelRecord(chan)->stat, dbChannelRecord(chan)->sevr);
> return status;
> static long dbDbGetControlLimits(const struct link *plink, double *low,
> double *high)
> - DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
> struct buffer {
> DBRctrlDouble
> double value;
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Build failed: epics-base base-dynamic-rRDD-500 AppVeyor via Core-talk
<2020>
2025
2026
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
<2020>
2025
2026
