2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mdavidsaver <mdavidsaver at gmail.com>
Date: Tue, 19 May 2020 13:53:23 -0000
> 1. Please avoid merging 7.0 in a feature branch.  git-rebase is the preferred
> way to update (if necessary).
OK. Un-merged.
> 2. I do my local builds with -Werror=implicit-function-declaration
>    which turns up a missing '#define EPICS_PRIVATE_API' in dbChannel.c
Oops. Fixed.
> Also, as a minor point.  There is no reason to decorate private API like
> db_init_event_freelists() with epicsShareFunc unless it is called from test
> code.
I never know when those Windows decorations are needed. Removed.
I will force-push these fixes.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Prev: Build failed: epics-base base-dynamic-rRDD-500 AppVeyor via Core-talk
Next: [Bug 1853148] Re: mingw compiler problem with printf/scanf formats Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 19 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
