2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Sat, 16 May 2020 02:08:29 -0000
Two points.
1. Please avoid merging 7.0 in a feature branch.  git-rebase is the preferred way to update (if necessary).
2. I do my local builds with -Werror=implicit-function-declaration
   which turns up a missing '#define EPICS_PRIVATE_API' in dbChannel.c
../db/dbChannel.c:70:5: error: implicit declaration of function ‘db_init_event_freelists’; did you mean ‘db_init_events’? [-Werror=implicit-function-declaration]
     db_init_event_freelists();
     db_init_events
Also, as a minor point.  There is no reason to decorate private API like db_init_event_freelists() with epicsShareFunc unless it is called from test code.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 19 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
