2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Thu, 07 May 2020 14:47:34 -0000
All points taken care off. I will push a new version now.
Diff comments:
> diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
> index 19f6038..9b149dd 100644
> --- a/modules/database/src/ioc/db/dbAccess.c
> +++ b/modules/database/src/ioc/db/dbAccess.c
> @@ -943,6 +943,11 @@ long dbGet(DBADDR *paddr, short dbrType,
>          } else {
>              DBADDR localAddr = *paddr; /* Structure copy */
> +            if (pfl->no_elements < 1) {
> +                status = S_db_badField;
> +                goto done;
Correct, no_elements is always equal to pfl->no_elements here.
I had added the test in the block where it crashed, but it should be possible to do it earlier, costing a few ticks maybe. Oops, When doing so, dbCaLinkTest hangs.
I am a bit reluctant to add new error codes but I have added S_db_emptyArray now.
Complexity comes for free. Simplicity is what one has to struggle for. I hope we can do something about this some day.
>              localAddr.field_type = pfl->field_type;
>              localAddr.field_size = pfl->field_size;
>              localAddr.no_elements = pfl->no_elements;
> diff --git a/modules/database/src/ioc/db/dbDbLink.c b/modules/database/src/ioc/db/dbDbLink.c
> index f2cb0c5..688cb7a 100644
> --- a/modules/database/src/ioc/db/dbDbLink.c
> +++ b/modules/database/src/ioc/db/dbDbLink.c
> @@ -160,47 +165,82 @@ static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
>          long *pnRequest)
>      struct pv_link *ppv_link = &plink->value.pv_link;
> -    DBADDR *paddr = ppv_link->pvt;
> +    dbChannel *chan = linkChannel(plink);
> +    DBADDR *paddr = &chan->addr;
>      dbCommon *precord = plink->precord;
> +    db_field_log *pfl = NULL;
>      long status;
>      /* scan passive records if link is process passive  */
>      if (ppv_link->pvlMask & pvlOptPP) {
> -        status = dbScanPassive(precord, paddr->precord);
> +        status = dbScanPassive(precord, dbChannelRecord(chan));
>          if (status)
>              return status;
> -    if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
> -        status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
> -    } else {
> -        unsigned short dbfType = paddr->field_type;
> +    if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType)
> +        /* shortcut: scalar with known conversion, no filter */
> +        status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
> +    else if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
> +                && dbChannelSpecial(chan) != SPC_DBADDR
> +                && dbChannelSpecial(chan) != SPC_ATTRIBUTE
> +                && ellCount(&chan->filters) == 0)
> +        /* simple scalar: set up shortcut */
> +        unsigned short dbfType = dbChannelFinalFieldType(chan);
>          if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
>              return S_db_badDbrtype;
> -        if (paddr->no_elements == 1 && (!pnRequest || *pnRequest == 1)
> -                && paddr->special != SPC_DBADDR
> -                && paddr->special != SPC_ATTRIBUTE) {
> -            ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
> -        } else {
> -            ppv_link->getCvt = NULL;
> -            status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
> +        ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
>          ppv_link->lastGetdbrType = dbrType;
The salar path is only taken if *pnRequest is already 1. Why set it again?
The shortcut is only taken when the salar path was taken before, so again *pnRequest is already 1.
> +    else
> +        /* filter, array, or special */
> +        ppv_link->getCvt = NULL;
> +        /* For the moment, empty arrays are not supported by EPICS */
> +        if (dbChannelFinalElements(chan) <= 0) /* empty array request */
> +            return S_db_badField;
Is it guaranteed? I have removed the test now.
> +        if (ellCount(&chan->filters)) {
> +            /* If filters are involved in a read, create field log and run filters */
> +            pfl = db_create_read_log(chan);
> +            if (!pfl)
> +                return S_db_noMemory;
> +            pfl = dbChannelRunPreChain(chan, pfl);
> +            pfl = dbChannelRunPostChain(chan, pfl);
> +        status = dbChannelGet(chan, dbrType, pbuffer, NULL, pnRequest, pfl);
> +        if (pfl)
> +            db_delete_field_log(pfl);
> +        if (status)
> +            return status;
> +        if (pnRequest && *pnRequest <= 0) /* empty array result */
> -    if (!status && precord != paddr->precord)
> +    if (!status && precord != dbChannelRecord(chan))
>          recGblInheritSevr(plink->value.pv_link.pvlMask & pvlOptMsMode,
> -            plink->precord, paddr->precord->stat, paddr->precord->sevr);
> +            plink->precord,
> +            dbChannelRecord(chan)->stat, dbChannelRecord(chan)->sevr);
>      return status;
>  static long dbDbGetControlLimits(const struct link *plink, double *low,
>          double *high)
> -    DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
>      struct buffer {
>          DBRctrlDouble
>          double value;
> diff --git a/modules/database/src/ioc/db/dbEvent.h b/modules/database/src/ioc/db/dbEvent.h
> index 374e849..175b0e4 100644
> --- a/modules/database/src/ioc/db/dbEvent.h
> +++ b/modules/database/src/ioc/db/dbEvent.h
> @@ -50,6 +50,7 @@ epicsShareFunc int db_post_events (
>  typedef void * dbEventCtx;
>  typedef void EXTRALABORFUNC (void *extralabor_arg);
> +void db_init_event_freelists (void);
Done. Does it make sense to have xxxPriv.h header files for such private APIs?
>  epicsShareFunc dbEventCtx db_init_events (void);
>  epicsShareFunc int db_start_events (
>      dbEventCtx ctx, const char *taskname, void (*init_func)(void *),
> diff --git a/modules/database/test/std/rec/linkFilterTest.c b/modules/database/test/std/rec/linkFilterTest.c
> new file mode 100644
> index 0000000..6f38d24
> --- /dev/null
> +++ b/modules/database/test/std/rec/linkFilterTest.c
> @@ -0,0 +1,157 @@
> +* Copyright (c) 2020 Dirk Zimoch
> +* EPICS BASE is distributed subject to a Software License Agreement found
> +* in file LICENSE that is included with this distribution.
> +#include <string.h>
> +#include "dbAccess.h"
> +#include "devSup.h"
> +#include "alarm.h"
> +#include "dbUnitTest.h"
> +#include "errlog.h"
> +#include "epicsThread.h"
> +#include "longinRecord.h"
> +#include "testMain.h"
> +void recTestIoc_registerRecordDeviceDriver(struct dbBase *);
> +static void startTestIoc(const char *dbfile)
> +    testdbPrepare();
> +    testdbReadDatabase("recTestIoc.dbd", NULL, NULL);
> +    recTestIoc_registerRecordDeviceDriver(pdbbase);
> +    testdbReadDatabase(dbfile, NULL, NULL);
> +    eltc(0);
> +    testIocInitOk();
> +    eltc(1);
> +static void expectProcSuccess(const char *rec)
> +    char fieldname[20];
> +    testDiag("expecting success from %s", rec);
> +    sprintf(fieldname, "%s.PROC", rec);
> +    testdbPutFieldOk(fieldname, DBF_LONG, 1);
> +    sprintf(fieldname, "%s.SEVR", rec);
> +    testdbGetFieldEqual(fieldname, DBF_LONG, NO_ALARM);
> +    sprintf(fieldname, "%s.STAT", rec);
> +static void expectProcFailure(const char *rec)
> +    testDiag("expecting failure S_db_badField %#x from %s", S_db_badField, rec);
> +    testdbPutFieldFail(S_db_badField, fieldname, DBF_LONG, 1);
> +    testdbGetFieldEqual(fieldname, DBF_LONG, INVALID_ALARM);
> +    testdbGetFieldEqual(fieldname, DBF_LONG, LINK_ALARM);
> +static void changeRange(long start, long stop, long step)
> +    char linkstring[60];
> +    if (step)
> +        sprintf(linkstring, "src.[%ld:%ld:%ld]", start, step, stop);
> +    else if (stop)
> +        sprintf(linkstring, "src.[%ld:%ld]", start, stop);
> +    else
> +        sprintf(linkstring, "src.[%ld]", start);
> +    testDiag("modifying link: %s", linkstring);
> +    testdbPutFieldOk("ai.INP", DBF_STRING, linkstring);
> +    testdbPutFieldOk("wf.INP", DBF_STRING, linkstring);
> +static double buf[] = {1, 2, 3, 4, 5, 6, 7, 8, 0, 0, 2, 4, 6};
Yes. But does it really matter? It is test code. Done anyway.
> +static void expectRange(long start, long end)
> +    long n = end-start+1;
> +    testdbGetFieldEqual("ai.VAL", DBF_DOUBLE, buf[start]);
> +    testdbGetFieldEqual("wf.NORD", DBF_LONG, n);
> +    testdbGetArrFieldEqual("wf.VAL", DBF_DOUBLE, n+2, n, buf+start);
> +#if 0
> +static void expectEmptyArray(void)
> +    /* empty arrays are now allowed at the moment */
> +    testDiag("expecting empty array");
> +    testdbGetFieldEqual("wf.NORD", DBF_LONG, 0);
> +#endif
Done.
> +MAIN(linkFilterTest)
> +    testPlan(98);
> +    startTestIoc("linkFilterTest.db");
> +    testDiag("PINI");
> +    expectRange(2,4);
> +    testDiag("modify range");
> +    changeRange(3,6,0);
> +    expectProcSuccess("ai");
> +    expectProcSuccess("wf");
> +    expectRange(3,6);
> +    testDiag("backward range");
> +    changeRange(5,3,0);
> +    expectProcFailure("ai");
> +    expectProcFailure("wf");
> +    testDiag("step 2");
> +    changeRange(1,6,2);
> +    expectRange(10,12);
> +    testDiag("range start beyond src.NORD");
> +    changeRange(8,9,0);
> +    testDiag("range end beyond src.NORD");
> +    changeRange(3,9,0);
> +    expectRange(3,7); /* clipped range */
> +    testDiag("range start beyond src.NELM");
> +    changeRange(11,12,0);
> +    testDiag("range end beyond src.NELM");
> +    changeRange(4,12,0);
> +    expectRange(4,7); /* clipped range */
> +    testDiag("single value beyond src.NORD");
> +    changeRange(8,0,0);
> +    testDiag("single value");
> +    changeRange(5,0,0);
> +    expectRange(5,5);
> +    testDiag("single beyond rec.NELM");
> +    changeRange(12,0,0);
> +    testIocShutdownOk();
> +    testdbCleanup();
> +    return testDone();
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-integration-483 AppVeyor via Core-talk
Next: Build completed: epics-base base-defaultMessageQueue-21 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 15 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
