2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Wed, 25 Mar 2020 14:20:38 -0000
After studying this for a while I think I understand the logic now.
Caching the conversion routine from the last time a request was made on this channel makes sense only if we circumvent the call to dbGet and call the conversion routine directly. This is what the last two cases are about.
I am not sure this optimization buys a lot. The code path inside dbGet up until the point where we call the conversion routine is mostly a small number of binary decisions and a few simple scalar assignments. We don't specify any options to dbGet (the MS link option is handled separately). Saving these few lines of code doesn't strike me as worth the trouble. The only noticeable benefit this could have is that we avoid the table lookup, which /may/ allow the processor to keep the conversion routine in the cache.
Has this ever been benchmarked?
Anyway, I will try to refactor this in my write-filters branch. It should be possible to make this optimization work with less complication by factoring out the code from dbGet up to the point where we know which conversion routine we want to call and then just return that pointer.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 25 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
