2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Wed, 25 Mar 2020 10:55:57 -0000
I have an additional comment/question about the code in dbDbLink.c, function dbDbGetValue, particularly the following case distinction:
    /* If filters are involved in a read, create field log and run filters */
    if (ellCount(&chan->filters)) {
        db_field_log *pfl;
         * For the moment, empty arrays are not supported by EPICS.
         * See the remark in src/std/filters/arr.c for details.
        if (dbChannelFinalElements(chan) <= 0) /* empty array request */
            return S_db_badField;
        pfl = db_create_read_log(chan);
        if (!pfl)
            return S_db_noMemory;
        pfl = dbChannelRunPreChain(chan, pfl);
        pfl = dbChannelRunPostChain(chan, pfl);
        status = dbChannelGet(chan, dbrType, pbuffer, NULL, pnRequest, pfl);
        db_delete_field_log(pfl);
        if (status)
            return status;
        if (pnRequest && *pnRequest <= 0) /* empty array result */
    } else if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
        status = ppv_link->getCvt(dbChannelField(chan), pbuffer, paddr);
    } else {
        unsigned short dbfType = dbChannelFinalFieldType(chan);
        if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
            return S_db_badDbrtype;
        if (dbChannelFinalElements(chan) == 1 && (!pnRequest || *pnRequest == 1)
                && dbChannelSpecial(chan) != SPC_DBADDR
                && dbChannelSpecial(chan) != SPC_ATTRIBUTE) {
            ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
        } else {
            ppv_link->getCvt = NULL;
            status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
        ppv_link->lastGetdbrType = dbrType;
Why handle the first case completely separate from the other two cases? If we have no filters then dbChannelRunPre/PostChain should be a no-op. Furthermore, shouldn't the actions done in the last case (the final "else" branch) also be done in the first case i.e. when we have filters?
The second case ("else if") is clearly an optimization. The code tells me that this optimization is not valid when there are filters, but it is unclear (to me at least) why this is the case.
I think this code should be re-written from scratch, after careful consideration of the expected behavior and possible optimization/caching.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:write-filters-rebased into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 25 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
