> mPollQueue(1, sizeof(acquisition_t))
https://github.com/search?q=org%3AareaDetector+mPollQueue&type=Code
So you're asking about byte-wise copying a std::string into
an epicsMessageQueue?
This is, and has always been, a really bad idea. It isn't safe to
mix C and C++ like this. You'll need to use something other than
epicsMessageQueue, or replace use of std::string with a plain char[].
I generally use a combination of std::deque, an epicsEvent, and an epicsMutex
to keep it all reentrant.
On 3/4/20 10:22 AM, Gofron, Kazimierz via Core-talk wrote:
> Hi,
> Since base is written in C, and many drivers are written in C++, we are seeing some issues for string, as discussed below.
> https://epics.anl.gov/tech-talk/2020/msg00515.php
> The g++ on Debian9 uses newer compiler than g++ > 5.2, and reports sizeof(string) up to 15.
> http://www.cplusplus.com/forum/beginner/173925/
> sizeof(std::string), in-object space for small string storage:
> GNU libstdc++ (conforming implementation, GCC 5.2 or later): *32, 15*
> LLVM libc++: *24, 22*
> Microsoft msc++ 19.00 (VS 2015): *28, 15*
> Is there a replacement / better way to use sizeof?
> Kazimierz Gofron
> NSLS-II Controls Group
> Brookhaven National Laboratory
> (p) +1 (631) 344 5283
> (f) +1 (631) 344 8085
> (e) kgofron at bnl.gov <mailto:kgofron at bnl.gov>
> (w) www.bnl.gov/nsls2 <http://www.bnl.gov/nsls2>
- RE: sizeof with g++ > 5.2 Gofron, Kazimierz via Core-talk
- sizeof with g++ > 5.2 Gofron, Kazimierz via Core-talk
<2020>
2025
2026
<2020>
2025
2026
