2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: sizeof with g++ > 5.2
From: "Gofron, Kazimierz via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 4 Mar 2020 18:47:27 +0000
Thanks Michael,
The pull request fixing it for Eiger was created. If there is a better solution, it would be good to implement it.
https://github.com/areaDetector/ADEiger/pull/35
Kazimierz
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Wednesday, 4 March 2020 1:38 PM
To: Gofron, Kazimierz <kgofron at bnl.gov>
Cc: core-talk at aps.anl.gov
Subject: Re: sizeof with g++ > 5.2
> mPollQueue(1, sizeof(acquisition_t))
https://github.com/search?q=org%3AareaDetector+mPollQueue&type=Code
So you're asking about byte-wise copying a std::string into an epicsMessageQueue?
This is, and has always been, a really bad idea.  It isn't safe to mix C and C++ like this.  You'll need to use something other than epicsMessageQueue, or replace use of std::string with a plain char[].
I generally use a combination of std::deque, an epicsEvent, and an epicsMutex to keep it all reentrant.
On 3/4/20 10:22 AM, Gofron, Kazimierz via Core-talk wrote:
> Hi,
> Since base is written in C, and many drivers are written in C++, we are seeing some issues for string, as discussed below.
> https://epics.anl.gov/tech-talk/2020/msg00515.php
> The g++ on Debian9 uses newer compiler than g++ > 5.2, and reports sizeof(string) up to 15.
> https://urldefense.com/v3/__http://www.cplusplus.com/forum/beginner/17
> 3925/__;!!P4SdNyxKAPE!XlzJJcWrnHxeg7alin7yo19b8wyTCIqz5vH09d9rgjKYVub2
> plQCLzhbjdfqBvID$
> sizeof(std::string), in-object space for small string storage:
> GNU libstdc++ (conforming implementation, GCC 5.2 or later): *32, 15*
> LLVM libc++: *24, 22* Microsoft msc++ 19.00 (VS 2015): *28, 15*
> Is there a replacement / better way to use sizeof?
> Kazimierz Gofron
> NSLS-II Controls Group
> Brookhaven National Laboratory
> (p) +1 (631) 344 5283
> (f) +1 (631) 344 8085
> (e) kgofron at bnl.gov <mailto:kgofron at bnl.gov>
> (w) http://www.bnl.gov/nsls2 <http://www.bnl.gov/nsls2>
sizeof with g++ > 5.2 Gofron, Kazimierz via Core-talk
Re: sizeof with g++ > 5.2 Michael Davidsaver via Core-talk
Prev: Re: sizeof with g++ > 5.2 Michael Davidsaver via Core-talk
Next: Build failed: epics-base base-epicsTempFile-C-11 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 05 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
