2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: write to a single element of an array field
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Sun, 22 Mar 2020 11:13:42 +0100
Am 19.03.20 um 19:49 schrieb Ralph Lange via Core-talk:
> A bit of background:
> The name db field log was the traditional one. When adding the filters, I
> started to do a refactoring of the code to use more comprehensive names for
> some of the core concepts, and trashed it after a few hours, because I was
> getting commits that changed every line of the code, which I was sure not
> to get past QAndrew.
> Originally, there had to be two types of updates (field logs):
> 1. scalar data, where the value and all metadata (incl. timestamp) was in
> the update, and the post-queue processing was copying data from the update.
> 2. array data, where the update contained a pointer to the record, and the
> post-queue processing accessed the record to copy the data out. (into the
> CA buffers)
> When adding filters that are able to change the data and metadata of an
> array, there is a need for a third type:
> 3. manipulated array data, where the changed metadata is in the update, and
> the array data is a copy allocated on the heap, i.e. has to be free()d
> after post-queue processing.
> The admittedly weird way this extension was merged into the original
> db_field_log structure was intended to keep the changes minimally invasive.
After my second failed attempt at refactoring this mess I can quite well
appreciate the difficulties you encountered.
Judging from your explanation and what I learned from my experiments, I
think the essential difference between dbfl_type_rec and dbfl_type_ref
is the locking: with dbfl_type_ref we know that we are working with a
copy of the (array) data, so there is no need to lock the record,
whereas with dbfl_type_rec the array is still owned by the record. I
wonder if dbfl_type_rec could be replaced with a simple flag in dbfl_ref
that indicates whether the data pointer is owned by the record or by a
freeList. I will experiment with this idea and see how far I get this time.
Here is the the first thing I am seriously stumbling over:
static void db_queue_event_log (evSubscrip *pevent, db_field_log *pLog)
     * if we have an event on the queue and both the last
     * event on the queue and the current event are emtpy
     * (i.e. of type dbfl_type_rec), simply ignore duplicate
     * events (saving empty events serves no purpose)
    if (pevent->npend > 0u &&
        (*pevent->pLastLog)->type == dbfl_type_rec &&
        pLog->type == dbfl_type_rec) {
        db_delete_field_log(pLog);
        UNLOCKEVQUE (ev_que);
        return;
I don't quite get the logic here. What is (the definition of) an empty
event? And why does dbfl_type_rec indicate that the event is empty?
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: pEpkey.asc
Description: application/pgp-keys
Re: write to a single element of an array field Ben Franksen via Core-talk
Re: write to a single element of an array field Ralph Lange via Core-talk
Prev: Re: write to a single element of an array field Ben Franksen via Core-talk
Next: Error (511,511) Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: write to a single element of an array field Ben Franksen via Core-talk
ANJ, 23 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
