2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: write to a single element of an array field
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: Ben Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 23 Mar 2020 12:10:06 +0100
On Sun, 22 Mar 2020 at 11:13, Ben Franksen <benjamin.franksen at helmholtz-berlin.de> wrote:
Here is the the first thing I am seriously stumbling over:
static void db_queue_event_log (evSubscrip *pevent, db_field_log *pLog)
     * if we have an event on the queue and both the last
     * event on the queue and the current event are emtpy
     * (i.e. of type dbfl_type_rec), simply ignore duplicate
     * events (saving empty events serves no purpose)
    if (pevent->npend > 0u &&
        (*pevent->pLastLog)->type == dbfl_type_rec &&
        pLog->type == dbfl_type_rec) {
        db_delete_field_log(pLog);
        UNLOCKEVQUE (ev_que);
        return;
I don't quite get the logic here. What is (the definition of) an empty
event? And why does dbfl_type_rec indicate that the event is empty?
Probably a bad term.
A dbfl_type_rec update does not contain any data or metadata by itself - that's why I called it "empty". It's just a placeholder, signaling to the post-queue processing that it should use the current state and data of the record, including all metadata and timestamp.
Putting two consecutive dbfl_type_rec events on the queue would lead to an identical update (as all data is taken from the record) being sent twice. Not really useful, that's why I decided it to be safe to drop any consecutive dbfl_type_rec updates.
Cheers,
~Ralph
Re: write to a single element of an array field Ben Franksen via Core-talk
Re: write to a single element of an array field Ralph Lange via Core-talk
Prev: Re: write to a single element of an array field Ralph Lange via Core-talk
Next: Re: write to a single element of an array field Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: write to a single element of an array field Ben Franksen via Core-talk
ANJ, 23 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
