2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+378968 at code.launchpad.net
Date: Thu, 26 Mar 2020 18:33:24 -0000
Am 26.03.20 um 16:17 schrieb Dirk Zimoch via Core-talk:
> It seems what really eats up time is db_create_read_log(), not
> running the empty list of filters. Skipping it gives 200-400 ns
> instead of 800-1200 (sometimes 120000) ns when only skipping the
> filters. Running or not running empty filter lists makes almost no
> difference.
I am not surprised. Running two empty for-loops amounts to testing the
loop condition twice. That should have a negligable impact.
> My guess is on the free list mutex. Maybe a new,
> lock-free implementation of the freeList would help.
That sounds plausible. I wasn't aware that allocating from a freeList
needs to take a mutex lock but of course it makes sense that it has to.
Still, before spending time on a new freeList implementation I would try
to verify this with a profiler.
This isn't directly related, but I have been wondering about some of the
uses of freeLists for filters, particularly the array filter. The global
freeList for the filter parameters is okay, but we also use a separate
freeList for each filter to store the actual array data. This doesn't
make much sense to me: the filter is invoked post-queue, so the theread
that invokes it is also the one that consumes the result. So we could as
well re-use the same space for all requests during the lifetime of the
filter.
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/378968
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Ben Franksen via Core-talk
Next: [Merge] ~bfrk/epics-base:write-filters-rebased into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 26 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
