All,
I've run up against a strange behavior with MSVC. I've reduced the problem somewhat,
but which I'm not sure how to proceed. This might have something to do with the
MSVC pre-processor, implicit concatenation of string constants, or maybe vararg functions.
It has to do with how I'm trying to do logging. At core I have a function:
> void _log_printf(unsigned lvl, const char* fmt, ...);
which internally calls errlogVprintf()
I'm calling it through two levels of macro. eg.
> #define log_info_printf(LOGGER, ...) log_printf(LOGGER, ::pvxs::Level::Info, __VA_ARGS__)
> #define log_printf(LOGGER, LVL, FMT, ...) do{ \
> if((LOGGER).test(LVL)) \
> ::pvxs::detail:: _log_printf(unsigned(LVL), "%s " FMT, "", __VA_ARGS__); \
> }while(0)
called like:
> log_info_printf(logerr, "Enter loop worker for %p\n", base.get());
The reason for the second level of macro is that I'd like to prefix each log line
with some extra information, including a timestamp, in a way which can't be split.
(as could happen if I called errlogPrintf() twice)
The above is already a reduced case. The empty string constant "" after FMT will be
replaced with a char* returned by a function (a thread local buffer). However, I can't
get that far.
The above, with the empty string constant, is somehow corrupting output and crashing.
eg.
> `b"l� Enter loop worker for 00007FFA6C34DCC0
If I change the log_printf macro as follows, then everything is fine (sans timestamp).
> ::pvxs::detail:: _log_printf(unsigned(LVL), FMT, __VA_ARGS__); \
> }while(0)
Does anyone have an idea of what is going on here?
I don't think I'm depending on any GCC-isms here. (eg. __VA_ARGS__ always has
at least one argument) And '"%s " FMT' should be taking advantage of automatic
concatenation of string constants.
I'm seeing this on appveyor with the MSVC 2019, 2017, and 2015.
mingw builds work fine.
https://ci.appveyor.com/project/mdavidsaver/pvxs
the full version I'm starting from (and would like to end with).
https://github.com/mdavidsaver/pvxs/blob/e2a7e5e451a06e3865b8684e747dfaa6026a6e15/src/pvxs/log.h#L77-L80
- RE: MSVC printf/vararg weirdness Freddie Akeroyd - UKRI STFC via Core-talk
merge requests for dbChannelForDBLinks et al. Michael Davidsaver via Core-talk
[Bug 1868486] Re: epicsMessageQueue lost messages rivers via Core-talk
<2020>
2025
2026
Re: merge requests for dbChannelForDBLinks et al. Ben Franksen via Core-talk
<2020>
2025
2026
