2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1879532] [NEW] Can't completely shutdown libCa and libCom
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 19 May 2020 16:46:28 -0000
Public bug reported:
Most recently, Carsten Winkler reported in https://epics.anl.gov/tech-
talk/2020/msg00946.php
    For a project I need to load and unload the Channel Access context in a
    shared library. Loading is no problem but unloading. It always fails
    during ca_context_destroy() function.
This problem has been reported and discussed previously, see
https://epics.anl.gov/tech-talk/2017/msg00371.php and
https://epics.anl.gov/tech-talk/2004/msg00743.php thus it is a known
issue which would probably require significant work to fix.
This bug report is a place-holder for any work towards making it
possible to completely shut down all libCom background threads and
releasing the resources allocated by those subsystems.
** Affects: epics-base
     Importance: Wishlist
         Status: Confirmed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1879532
Title:
Status in EPICS Base:
  Confirmed
Bug description:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1879532/+subscriptions
[Bug 1879532] Re: Can't completely shutdown libCa and libCom Peter Heesterman via Core-talk
[Bug 1879532] Re: Can't completely shutdown libCa and libCom Freddie Akeroyd via Core-talk
[Bug 1879532] Re: Can't completely shutdown libCa and libCom Andrew Johnson via Core-talk
Prev: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
Next: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Bug 1879532] Re: Can't completely shutdown libCa and libCom Peter Heesterman via Core-talk
ANJ, 09 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
