2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1879532] Re: Can't completely shutdown libCa and libCom
From: Freddie Akeroyd via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 20 May 2020 23:33:16 -0000
Hi @pheest, interesting article - did you implement the two part DLL
solution mentioned?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1879532
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  Most recently, Carsten Winkler reported in https://epics.anl.gov/tech-
  talk/2020/msg00946.php
      For a project I need to load and unload the Channel Access context in a
      shared library. Loading is no problem but unloading. It always fails
      during ca_context_destroy() function.
  This problem has been reported and discussed previously, see
  https://epics.anl.gov/tech-talk/2017/msg00371.php and
  https://epics.anl.gov/tech-talk/2004/msg00743.php thus it is a known
  issue which would probably require significant work to fix.
  This bug report is a place-holder for any work towards making it
  possible to completely shut down all libCom background threads and
  releasing the resources allocated by those subsystems.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1879532/+subscriptions
[Bug 1879532] [NEW] Can't completely shutdown libCa and libCom Andrew Johnson via Core-talk
Prev: Jenkins build is back to stable : epics-pva2pva-linux32 #178 APS Jenkins via Core-talk
Next: Build failed: epics-base base-doc-sim-mode-330 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1879532] Re: Can't completely shutdown libCa and libCom Andrew Johnson via Core-talk
Next: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Johnson, Andrew N. via Core-talk
ANJ, 20 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
