2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RTEMS/osdMessageQueue.c
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 25 May 2020 17:49:46 +0000
tl;dr:  I propose that we delete the RTEMS implementation of osdMessageQueue before making the 7.0.3.2 release, it has bugs which the default implementation doesn’t show.
The long version:
While merging 3.15 into 7.0 last night I ran the tests on RTEMS (qemu) and discovered that the implementation of the epicsMessageQueue fails the additional tests that I wrote for this API. I was expecting the Travis-CI builds to fail but I forgot that they don’t actually run the tests at all. In the RTEMS implementation of the epicsMessageQueue Eric added an rtems_message_queue_send_timeout() routine which the rtems_message_queue type doesn’t come with. These were the results I saw for these tests:
# 6 Single receiver single sender 'Sleepy timeout' tests,
#     these should take about 5.00 seconds each:
# sleepySender: sending every 0.009 seconds
ok 57 - Sent 500 (should be 500)
ok 58 - Received 500 (should be 500)
# sleepySender: sending every 0.010 seconds
ok 59 - Sent 500 (should be 500)
ok 60 - Received 500 (should be 500)
# sleepySender: sending every 0.011 seconds
ok 61 - Sent 500 (should be 500)
ok 62 - Received 500 (should be 500)
# sleepyReceiver: acquiring every 0.009 seconds
not ok 63 - Sent 420 (should be 500)
ok 64 - Received 500 (should be 500)
# sleepyReceiver: acquiring every 0.010 seconds
not ok 65 - Sent 420 (should be 500)
ok 66 - Received 500 (should be 500)
# sleepyReceiver: acquiring every 0.011 seconds
not ok 67 - Sent 420 (should be 500)
ok 68 - Received 500 (should be 500)
So far every time I have run this test the numSent counter has always come back as 420 instead of 500. The fastSender() code looks like this:
extern "C" void
fastSender(void *arg)
    epicsMessageQueue *q = (epicsMessageQueue *)arg;
    numSent = 0;
    // Send first without timeout
    q->send((void *)msg1, 4);
    numSent++;
    // The rest have a timeout
    while (!sendExit) {
        if (q->send((void *)msg1, 4, 0.010) == 0) {
            numSent++;
    sendExit = 0;
    epicsEventSignal(complete);
The epicsMessageQueueSendWithTimeout() routine must sometimes be returning an error (non-zero value) even though it has successfully queued the message; I confirmed that by incrementing a local numFailed counter on the else branch, which always counted to 580. This was the output from a normal run on linux, which is about what I would expect:
ok 63 - Sent 500 (should be 500)
# numFailed = 0
ok 65 - Sent 500 (should be 500)
# numFailed = 204
ok 67 - Sent 500 (should be 500)
# numFailed = 500
Instead of trying to fix the RTEMS code I propose that we delete the RTEMS implementation completely, causing RTEMS to use the default implementation which gives me these test results when run on qemu:
# numFailed = 80
# numFailed = 80
# numFailed = 80
Any objections? Discussion?
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: RTEMS/osdMessageQueue.c Michael Davidsaver via Core-talk
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #224 APS Jenkins via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-15 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: RTEMS/osdMessageQueue.c Michael Davidsaver via Core-talk
ANJ, 25 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
