2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS/osdMessageQueue.c
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 2 Jun 2020 17:37:27 -0700
On 5/25/20 11:37 AM, Michael Davidsaver wrote:
> On 5/25/20 10:49 AM, Johnson, Andrew N. via Core-talk wrote:
>> tl;dr:  I propose that we delete the RTEMS implementation of osdMessageQueue before making the 7.0.3.2 release, it has bugs which the default implementation doesn’t show.
> I don't have a strong objection to this.  Although, I'm not enthused to be
> making this change days before a release, when it will go out the door with
> very little testing.  Whatever is going on, I suspect that it isn't a
> regression (the bugs in the default impl weren't).
> How about marking your new test as a skip until after the release?
Since the 7.0.4 release has been cut, I no longer have any objection to this change.
RTEMS/osdMessageQueue.c Johnson, Andrew N. via Core-talk
Re: RTEMS/osdMessageQueue.c Michael Davidsaver via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-linux32 #468 APS Jenkins via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS/osdMessageQueue.c Heinz Junkes via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-15 AppVeyor via Core-talk
ANJ, 03 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
