2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: make runtests fails with "touch: missing file operand"
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Wed, 3 Jun 2020 08:06:55 +0000
In the current 7.0 branch, running 'make runtests' ends with an error:
All tests successful.
Files=11, Tests=293,  1 wallclock secs ( 0.07 usr  0.01 sys +  0.25 cusr  0.07 csys =  0.40 CPU)
Result: PASS
make[5]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test/tools/O.linux-x86_64'
make[4]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test/tools'
make[3]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test'
make[2]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database'
Try 'touch --help' for more information.
make[1]: *** [runtests] Error 1
make[1]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules'
make: *** [modules.runtests] Error 2
Re: make runtests fails with "touch: missing file operand" Johnson, Andrew N. via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-23 AppVeyor via Core-talk
Next: Build failed: epics-base base-vfield-514 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: make runtests fails with "touch: missing file operand" Johnson, Andrew N. via Core-talk
ANJ, 03 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
