2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: make runtests fails with "touch: missing file operand"
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Dirk Zimoch <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 3 Jun 2020 17:59:56 +0000
Hi Dirk,
On Jun 3, 2020, at 3:06 AM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
In the current 7.0 branch, running 'make runtests' ends with an error:
All tests successful.
Files=11, Tests=293,  1 wallclock secs ( 0.07 usr  0.01 sys +  0.25 cusr  0.07 csys =  0.40 CPU)
Result: PASS
make[5]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test/tools/O.linux-x86_64'
make[4]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test/tools'
make[3]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database/test'
make[2]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules/database'
Try 'touch --help' for more information.
make[1]: *** [runtests] Error 1
make[1]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-work/modules'
make: *** [modules.runtests] Error 2
Looking at configure/RULES_MODULES I can see that this can happen if you have none of the submodules checked out. That is a legitimate configuration for Base which I know you use but I didn’t test, so my mistake, sorry!
Ralph – it wasn’t so much that there was a space in a variable, but that the rule wasn’t expecting the list of submodules to be empty.
Here’s a patch that should fix the problem, please let me know if it does so I can commit it (careful with wrapping, there are some long lines in it).
diff --git a/configure/RULES_MODULES b/configure/RULES_MODULES
index a163ce18d..57a459173 100644
--- a/configure/RULES_MODULES
+++ b/configure/RULES_MODULES
@@ -50,9 +50,11 @@ realclean:
 # Append all our live submodule failure files
 FAILURE_FILES = $(addsuffix /$(TEST_FAILURE_FILENAME), $(LIVE_SUBMODULES))
-runtests: | $(addsuffix $(DIVIDER)runtests, $(LIVE_SUBMODULES))
+define combine_failure_files
        @$(TOUCH) $(FAILURE_FILES)
        @$(CAT) $(FAILURE_FILES) >> $(TEST_FAILURE_FILE)
+endef
+runtests: | $(addsuffix $(DIVIDER)runtests, $(LIVE_SUBMODULES))
+       $(if $(FAILURE_FILES), $(combine_failure_files))
 test-results: | $(addsuffix $(DIVIDER)test-results, $(LIVE_SUBMODULES))
-       @$(TOUCH) $(FAILURE_FILES)
-       @$(CAT) $(FAILURE_FILES) >> $(TEST_FAILURE_FILE)
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: make runtests fails with "touch: missing file operand" Michael Davidsaver via Core-talk
make runtests fails with "touch: missing file operand" Zimoch Dirk (PSI) via Core-talk
Prev: Re: EPICS 7 and VxWorks 6.9 for PPC604? Johnson, Andrew N. via Core-talk
Next: Re: make runtests fails with "touch: missing file operand" Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: make runtests fails with "touch: missing file operand" Zimoch Dirk (PSI) via Core-talk
ANJ, 03 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
