2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1882520] Re: Constant arrary input links of size 1 don't work
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 09 Jun 2020 07:56:14 -0000
I have tested with 3.14.12 and found that "" is fine as a record name, but segfaults when linking to it (or rather to ".VAL" as linking to "" itself does not work of course).
Also " " and "a b" and even "\"" work as record names but print warnings. Linking to them is impossible though.
I have no problem at all with the record names "1,3" or "[1,3]" or linking to them in 3.14.12.
But in EPICS 7 of course instead of linking to [1,3] I get a constant array.
Also using TAB as the record name works fine in 3.14.7 but I cant link
to it any more in 7.
That means EPICS 7 already broke my perfectly working database. Of
course only because I used silly record names.
I don't seen why we should care more about compatibility with records []
and [42] than with [1,3]?
I am very fond of the principle of least surprise. So what would be the bigger surprise?
a) [42] and [] are not valid record names
b) [42,43] and [42,] are valid arrays but [42] and  [] are not
To me, b) was a big surprise.
What about a rule like:
1. No dot (.), no quotes (" and '), no chars below ASCII/Unicode 0x21.
2. First char is none of: {[<(
3. Otherwise any unicode char (e.g. !äßáñ絚录)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Constant input links in array form with 1 element don't work and
  return an empty array.
  Example:
  field (INP, [42])
  As soon as a comma is present, it works:
  field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
Re: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Ben Franksen via Core-talk
[Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Prev: Re: DBR_VFIELD and complex field types Ralph Lange via Core-talk
Next: Build failed: epics-base base-vfield-530 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
Next: Re: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Ben Franksen via Core-talk
ANJ, 13 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
