2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Bug 1882520] Re: Constant arrary input links of size 1 don't work
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 13 Jun 2020 14:22:45 -0000
FWIW, I am with Dirk here. I would go even further: I do /not/ expect
any arbitrary existing database from 3.x to work with 7 without changes.
To the contrary, experience tells me that I /always/ need to tweak some
things when porting an application to a new (major) base version. For
instance some fields of standard records have gotten new types in EPICS
7 (or perhaps that was 3.14->3.15). And renaming a few records with
funny characters in them really isn't that much effort IMO.
This is why I think that for EPICS 7 we should define which characters
are allowed and that set should be as limited as acceptable by the
community in order to make future enhancements easier.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Constant input links in array form with 1 element don't work and
  return an empty array.
  Example:
  field (INP, [42])
  As soon as a comma is present, it works:
  field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
[Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
[Bug 1882520] Re: Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-27 AppVeyor via Core-talk
Next: Build failed: epics-base base-alarm-msg-544 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Next: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
ANJ, 13 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
