I think a bigger surprise would be a site that developed a record naming
convention that carefully followed our published naming rules and then
found out that they can't upgrade EPICS because we changed those rules.
Some EPICS sites don't have developers who have time to read every tech-
talk message, and that possibility troubles me.
If you don't like surprises, don't use the [] constant array syntax at all, use {const:[...]} instead as the JSON parser does follow the spec. The current parser (without your change) gives these occasionally surprising results:
field(INP, [1]) INP : DB_LINK [1] NPP NMS
field(INP, [1,2]) INP : CONSTANT [1,2]
field(INP, "[1]") INP : DB_LINK [1] NPP NMS
field(INP, "[1,2]") INP : CONSTANT [1,2]
field(INP, [a]) INP : CONSTANT ["a"]
field(INP, [a,b]) INP : CONSTANT ["a","b"]
field(INP, "[a]") INP : DB_LINK [a] NPP NMS
field(INP, "[a,b]") INP : CONSTANT [a,b] <-- This generates a parse error at iocInit
The INP: part on each line is from a dbpr of the record and shows
plink->type.
Applying your patch converts the 3 DB_LINKs into CONSTANTs, and adds a
second parse error:
field(INP, [1]) INP : CONSTANT [1]
field(INP, "[1]") INP : CONSTANT [1]
field(INP, "[a]") INP : CONSTANT [a] <-- Parse error at iocInit
field(INP, "[a,b]") INP : CONSTANT [a,b] <-- Parse error at iocInit
Links that give parse errors do not initialize their record at all. I
know exactly why they happen so don't waste time investigating them, I
have a fix in the works when we introduce the JSON-5 version of the YAJL
parser, although putting array constants inside quotes isn't really
correct anyway.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Constant arrary input links of size 1 don't work
Status in EPICS Base:
In Progress
Bug description:
Constant input links in array form with 1 element don't work and
return an empty array.
Example:
field (INP, [42])
As soon as a comma is present, it works:
field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
- [Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Re: DBR_VFIELD and complex field types Johnson, Andrew N. via Core-talk
RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
<2020>
2025
2026
Re: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Ben Franksen via Core-talk
[Bug 1882520] Re: Constant arrary input links of size 1 don't work mdavidsaver via Core-talk
<2020>
2025
2026
