2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1882520] Re: Constant arrary input links of size 1 don't work
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 13 Jun 2020 14:52:20 -0000
I'm also in agreement with Dirk, though I won't go as far as Ben.  "a
few records" doesn't capture the potential effects.  At the time, these
are 'potential' effects.  Based on lackluster response to my tech-talk
mail, I think the reasonable course of action is to add new restrictions
as warnings.  These would remain warnings for some years to give sites
an opportunity to notice them and request changes.  I would then lean
towards loosening restrictions to avoid orphaning whole sites from
future updates.
So I begin with:
https://github.com/epics-base/epics-base/pull/78
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1882520
Title:
Status in EPICS Base:
  In Progress
Bug description:
  Constant input links in array form with 1 element don't work and
  return an empty array.
  Example:
  field (INP, [42])
  As soon as a comma is present, it works:
  field (INP, [42,])
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1882520/+subscriptions
[Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-alarm-msg-544 AppVeyor via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-28 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:fix_one_element_input_link_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 13 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
