2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis)
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 10 Jun 2020 12:45:54 +0200
Hi Mark,
On Wed, 10 Jun 2020 at 02:00, Mark Rivers <rivers at cars.uchicago.edu> wrote:
I have a question about what version of EPICS base BASE=7.0 actually is.  Is that a specific tag, or is it the tip of the 7.0 branch?
As Michael wrote, the setting must refer to the name of a branch or tag. In the case of the EPICS Base repo, '7.0' is the name of a branch.
Another question.  In base7.set I define MODULES="sncseq".  When building for RTEMS I use base7.set, but I want to add “ipac” to MODULES.  Is there a syntax to do that?  If I use this line:
  - env: SET=base7 RTEMS=4.10 MODULES="ipac"
There is the ADD_MODULES setting to allow adding modules to specific builds.
(Documented in the README.)
First I had a minor problem.  The .travis.yml.example-full file does not have an example of using the SET argument.  I was doing SET=base7.set, and I got an error message saying .ci-local/base7.set does not exist. But it does exist.  The problem is that the .set extension must be omitted, so it should be SET=base7.
Yes, without the extension.
I will fix the misleading error message.
Some of the builds are working, but some are failing for reasons I don’t understand. You can see them here: https://travis-ci.org/github/epics-modules/asyn/builds/696643004
The mingw cross builds for Windows  both fail with this error:
$ mingw --version
Traceback (most recent call last):
MinGW builds are now using the 'compiler: gcc' setting, both for the cross builds from Linux and for the native Windows builds.
You can just remove the 'compiler:' setting from your job lines, as 'gcc' is the default.
(Documented in the example config file.)
Also: the 'STATIC=YES/NO' setting has been replaced by 'BCFG=default/static/debug/static-debug'.
(Also shown in the example config file.)
Cheers,
~Ralph
RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
Prev: Build failed: epics-base base-integration-533 AppVeyor via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis) Michael Davidsaver via Core-talk
Next: RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
ANJ, 10 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
