2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RE: BETA: ci-scripts 3.0 (feat. Windows on Travis)
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: 'Ralph Lange' <ralph.lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 10 Jun 2020 20:09:30 +0000
Hi Ralph,
Mea culpa, I should have looked at the README.md more carefully. ADD_MODULES was exactly what I was looking for.
Ø  Yes, without the extension.
Ø  (Documented in the README.)
Actually I think the README only documents omitting the .set in the context of the “include” statement, not the SET statement.  There is one example (SET=stable) that omits the .set.
Ø  MinGW builds are now using the 'compiler: gcc' setting, both for the cross builds from Linux and for the native Windows builds.
Ø  You can just remove the 'compiler:' setting from your job lines, as 'gcc' is the default.
Removing compiler: mingw fixed the error, the mingw jobs now succeed.
Ø  Also: the 'STATIC=YES/NO' setting has been replaced by 'BCFG=default/static/debug/static-debug'.
Yes, I had made all of those changes already.
Now my asyn build is only failing on the static-debug builds on Windows with both gcc and vs2017.  https://travis-ci.org/github/epics-modules/asyn/builds/696901014
Those builds fail for different reasons.
Michael said those are known problems that are under investigation?
The gcc build is just “timing out” with no response after 10 minutes.  I sometimes see a similar problem on my Windows machine if I use “make –j” rather than “make –j8” for example.  One “make” process is just sitting there using 100% of a core.  What –j count is being used by that job?  Is see that cue.py has these lines:
cue.py:    parallel = kws.pop('parallel', 2)
cue.py:        makeargs = ['-j{0}'.format(parallel)]
I suspect that means there is a default value of –j2.  How does one specify a different value for “parallel”?
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Ralph Lange via Core-talk
Sent: Wednesday, June 10, 2020 5:46 AM
To: EPICS Core Talk <core-talk at aps.anl.gov>
Subject: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis)
Hi Mark,
On Wed, 10 Jun 2020 at 02:00, Mark Rivers <rivers at cars.uchicago.edu> wrote:
I have a question about what version of EPICS base BASE=7.0 actually is.  Is that a specific tag, or is it the tip of the 7.0 branch?
As Michael wrote, the setting must refer to the name of a branch or tag. In the case of the EPICS Base repo, '7.0' is the name of a branch.
Another question.  In base7.set I define MODULES="sncseq".  When building for RTEMS I use base7.set, but I want to add “ipac” to MODULES.  Is there a syntax to do that?  If I use this line:
  - env: SET=base7 RTEMS=4.10 MODULES="ipac"
There is the ADD_MODULES setting to allow adding modules to specific builds.
First I had a minor problem.  The .travis.yml.example-full file does not have an example of using the SET argument.  I was doing SET=base7.set, and I got an error message saying .ci-local/base7.set does not exist. But it does exist.  The problem is that the .set extension must be omitted, so it should be SET=base7.
I will fix the misleading error message.
Some of the builds are working, but some are failing for reasons I don’t understand. You can see them here: https://travis-ci.org/github/epics-modules/asyn/builds/696643004
The mingw cross builds for Windows  both fail with this error:
$ mingw --version
Traceback (most recent call last):
(Documented in the example config file.)
(Also shown in the example config file.)
Cheers,
~Ralph
Re: BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
Prev: [Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
Next: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
ANJ, 10 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
