2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: BETA: ci-scripts 3.0 (feat. Windows on Travis)
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 10 Jun 2020 22:25:11 +0200
Hi Mark,
On Wed, 10 Jun 2020 at 22:09, Mark Rivers <rivers at cars.uchicago.edu> wrote:
Mea culpa, I should have looked at the README.md more carefully. ADD_MODULES was exactly what I was looking for.
I will make that clearer.
 Actually I think the README only documents omitting the .set in the context of the “include” statement, not the SET statement.  There is one example (SET=stable) that omits the .set.
Another thing that I will clarify in the doc.
 Ø  Also: the 'STATIC=YES/NO' setting has been replaced by 'BCFG=default/static/debug/static-debug'.
 Yes, I had made all of those changes already.
Well, job 19 still has "STATIC=YES" and job 21 has "BCFG=statuc", both of which will not cause the build to be linking statically.
I will make the script check more carefully and complain loudly.
What –j count is being used by that job?  Is see that cue.py has these lines:
cue.py:    parallel = kws.pop('parallel', 2)
cue.py:        makeargs = ['-j{0}'.format(parallel)]
I suspect that means there is a default value of –j2.  How does one specify a different value for “parallel”?
Not available through the API. I can add that.
The parallel value is supposed to be set per service, but all VMs that Travis and AppVeyor offer have 2 cores, so hard coded for the moment.
Thanks a lot for your feedback!
Cheers,
~Ralph
BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
Re: BETA: ci-scripts 3.0 (feat. Windows on Travis) Ralph Lange via Core-talk
Prev: RE: BETA: ci-scripts 3.0 (feat. Windows on Travis) Mark Rivers via Core-talk
Next: Build failed: EPICS Base 3.15 base-3.15-15 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: [Bug 1882520] [NEW] Constant arrary input links of size 1 don't work Dirk Zimoch via Core-talk
ANJ, 10 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
