2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Jenkins test failures on macOS
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 3 Aug 2020 19:37:03 -0700
On 8/3/20 6:07 PM, Johnson, Andrew N. wrote:
> No. I get non-zero milli- and microseconds in my time stamps now, but (counting after the decimal point) digits 7 through 9 of a %.9f seconds value are always zero.
Ok, then this seems likely to be no worse that Windows.
Out of curiosity, have you checked (eg. with epicsTimerTest)
to see what the minimum delta actually is?
Truncating to microseconds makes me wonder if this is really
just wrapping gettimeofday().
Re: Jenkins test failures on macOS Johnson, Andrew N. via Core-talk
Jenkins build became unstable: epics-7.0 » mac #245 APS Jenkins via Core-talk
Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
Prev: Re: Jenkins test failures on macOS Johnson, Andrew N. via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-58 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Jenkins test failures on macOS Johnson, Andrew N. via Core-talk
ANJ, 04 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
