2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Jenkins test failures on macOS
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 4 Aug 2020 01:07:58 +0000
No. I get non-zero milli- and microseconds in my time stamps now, but (counting after the decimal point) digits 7 through 9 of a %.9f seconds value are always zero.
- Andrew
Complicity is easy, Simplexity takes real work
> On Aug 3, 2020, at 6:54 PM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
> On 8/3/20 4:02 PM, Johnson, Andrew N. via Core-talk wrote:
>>> On Aug 3, 2020, at 4:36 PM, APS Jenkins via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>>> See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/245/display/redirect?page=changes>
>> So the change I committed earlier to Darwin's osdTimeGetCurrent() speeds it up significantly, but apparently at the expense of not giving nanosecond precision any more – I guess that’s probably not terribly surprising.
>> All my wall-clock timestamps now have 000 in the nanoseconds part,
> Do I read this correctly?  Effective time resolution would be limited to 1 second on Mac?
>> although the monotonic clock isn’t affected as it uses a different kernel API.
>> The failures in the above Jenkins Mac build were these:
>>> simmTest.tap ..............
>>> not ok 136 - time stamp is recent
>>> not ok 311 - time stamp is recent
>>> not ok 435 - time stamp is recent
>>> not ok 803 - time stamp is recent
>>> not ok 996 - time stamp is recent
>>> not ok 1171 - time stamp is recent
>>> Failed 6/1176 subtests
>>>    (42 TODO tests unexpectedly succeeded)
>> The problem is that in several places the test code is doing this:
>>> testOk(epicsTimeLessThan(&now, mytime), "time stamp is recent");
>> which fails when now and *mytime are identical. I am changing that code to:
>>> double diff = epicsTimeDiffInSeconds(mytime, &now);
>>> testOk(diff >= 0.0, "time stamp is recent (%.9f sec)", diff);
>> Equality is now always allowed, and we get to see how different the timestamps actually are.
>> One of these (but not all) is inside a testTodoBegin("imprecise"); region.
>> - Andrew
>> Complexity comes for free, simplicity you have to work for.
Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
Jenkins build became unstable: epics-7.0 » mac #245 APS Jenkins via Core-talk
Jenkins test failures on macOS Johnson, Andrew N. via Core-talk
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #246 APS Jenkins via Core-talk
Next: Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Jenkins test failures on macOS Michael Davidsaver via Core-talk
ANJ, 03 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
