2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: epicsExportShared symbols
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "Johnson, Andrew N." <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 11 Aug 2020 07:28:59 -0700
On 8/11/20 6:18 AM, Mark Rivers via Core-talk wrote:
> Hi Andrew,
> I am trying to figure out the best way to clean up my code (asyn, areaDetector, etc.) to handle the __declspec DLL_EXPORT/IMPORT stuff.
> I posted a comment to this thread in ADCore about it just now:
> https://github.com/areaDetector/ADCore/issues/455#issuecomment-671933786
> It looks like EPICS base 7.0.4 has 2 ways of doing it, for example using LIBCOM_API/LIBCA_API, or the more traditional epicsShareFunc and epicsExportSharedSymbols (e.g. in pvAccess).
> I did a "git grep LIBCOM_API" and I cannot actually figure out where LIBCOM_API is defined and how that mechanism works.  Can you explain?
> Does the LIBCA_API mechanism rely on anything in base 7, or can it be used with older versions of base?
Since the _API macros are my initiative, I'll answer this one.
For a support module, you might be better to start looking at
the pva2pva module, which is where I tried the idea before
changing Base.
https://github.com/epics-base/pva2pva/blob/master/pdbApp/pv/qsrv.h#L21-L37
With Base 7.0.4, this sort of header is generated by makeAPIheader.pl
to avoid repetition.  This did involve some Makefile changes to account
for dependency issues with use of a generated header by basically every
object file.
https://github.com/epics-base/epics-base/blob/7.0/src/tools/makeAPIheader.pl
RE: epicsExportShared symbols Mark Rivers via Core-talk
Prev: epicsExportShared symbols Mark Rivers via Core-talk
Next: Re: AW: Crash in EPICS 7 at iocInit Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: RE: epicsExportShared symbols Mark Rivers via Core-talk
ANJ, 11 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
