2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RE: epicsExportShared symbols
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: 'Michael Davidsaver' <mdavidsaver at gmail.com>, "Johnson, Andrew N." <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 11 Aug 2020 16:06:11 +0000
I note that in the comments at the beginning of shareLib.h in base 7.0.4 says that this construct is deprecated:
*     #ifdef epicsExportSharedSymbols
 *     #   define interfacePDQ_epicsExportSharedSymbols
 *     #   undef epicsExportSharedSymbols
 *     #endif
 *     #include "epicsTypes.h"
 *     #include "epicsTime.h"
 *     #ifdef interfacePDQ_epicsExportSharedSymbols
 *     #   define epicsExportSharedSymbols
 *     #   include "shareLib.h"
 *     #endif
 *     epicsShareFunc int myExtFunc ( int arg );
 *     epicsShareExtern int myExtVar;
 *     class epicsShareClass myClass {};mechanism being used in pvAccess,
However, that construct is still used in pvAccess, pvDatabase, normativeTypes, and pvaClient.
It seems to me that this construct has an advantage over the one that is preferred in shareLib.h.
Let's say I add a new dependency on EPICS base to myClass.h, for example epicsMutex.h.  It seems to me that with the preferred mechanism I must modify all .cpp files that include myClass.h to first include epicsMutex.h before defining epicsExportSharedSymbols and including myClass.h.  Otherwise myClass.h will end up exporting epicsMutex functions.  With the deprecated mechanism this is not necessary, and my .cpp files don't even need to include epicsMutex.h at all.
Am I missing something?
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Tuesday, August 11, 2020 9:29 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; Johnson, Andrew N. <anj at anl.gov>
Cc: core-talk at aps.anl.gov
Subject: Re: epicsExportShared symbols
On 8/11/20 6:18 AM, Mark Rivers via Core-talk wrote:
> Hi Andrew,
> I am trying to figure out the best way to clean up my code (asyn, areaDetector, etc.) to handle the __declspec DLL_EXPORT/IMPORT stuff.
> I posted a comment to this thread in ADCore about it just now:
> https://github.com/areaDetector/ADCore/issues/455#issuecomment-6719337
> 86
> It looks like EPICS base 7.0.4 has 2 ways of doing it, for example using LIBCOM_API/LIBCA_API, or the more traditional epicsShareFunc and epicsExportSharedSymbols (e.g. in pvAccess).
> I did a "git grep LIBCOM_API" and I cannot actually figure out where LIBCOM_API is defined and how that mechanism works.  Can you explain?
> Does the LIBCA_API mechanism rely on anything in base 7, or can it be used with older versions of base?
Since the _API macros are my initiative, I'll answer this one.
For a support module, you might be better to start looking at the pva2pva module, which is where I tried the idea before changing Base.
https://github.com/epics-base/pva2pva/blob/master/pdbApp/pv/qsrv.h#L21-L37
With Base 7.0.4, this sort of header is generated by makeAPIheader.pl to avoid repetition.  This did involve some Makefile changes to account for dependency issues with use of a generated header by basically every object file.
https://github.com/epics-base/epics-base/blob/7.0/src/tools/makeAPIheader.pl
Re: epicsExportShared symbols Michael Davidsaver via Core-talk
epicsExportShared symbols Mark Rivers via Core-talk
Prev: Re: epicsExportShared symbols Michael Davidsaver via Core-talk
Next: Re: epicsExportShared symbols Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 11 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
