Hi Andrew
I am definitely in support of such a change.
Cheers
Ben
Am 27.08.20 um 01:16 schrieb Johnson, Andrew N. via Core-talk:
> record(stringin, "si") {
> field(VAL, "This is a string")
> record(lsi, "lsi") {
> field(SIZV, 80)
> field(INP, "si")
> field(PINI, YES)
> record(aai, "aai") {
> field(NELM, 100)
> field(FTVL, CHAR)
> field(INP, "si")
> field(PINI, YES)
> record(waveform, "wf") {
> field(NELM, 100)
> field(FTVL, CHAR)
> field(INP, "si")
> field(PINI, YES)
> The lsi record's Soft Channel device support copies the string from the si record into the lsi.VAL field through its INP link. You can point an lsi link to either a DBF_STRING or an array of DBF_CHARs and it will handle either type.
> Should the aai and waveform records also get copies of that string when they process?
> Currently the aai.INP and wf.INP links read the si.VAL field and attempt to parse the string into an 8-bit integer, which they would then use to set the first element of their char arrays. The word “This” isn’t a valid integer, so the parsing fails and both arrays remain empty.
> I am considering making changes to the type conversion routines that would make the aai and waveform device supports Do What I Mean in the above cases, at the risk of breaking some very obscure conversions between strings and arrays of char (but not arrays of UCHAR). There would probably be some similar changes in the other direction too.
> Any objections? Comments?
> - Andrew
> Complexity comes for free, simplicity you have to work for.
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
-- Jonathan Nitzan and Shimshon Bichler: Capital as Power
signature.asc
Description: OpenPGP digital signature
- Opinions please, what should this database do Johnson, Andrew N. via Core-talk
Re: Minor issue with base 7.0.4.1 Ralph Lange via Core-talk
No access to epics-base.git for push junkes via Core-talk
<2020>
2025
2026
WG: Opinions please, what should this database do Zimoch Dirk (PSI) via Core-talk
<2020>
2025
2026
