2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Minor issue with base 7.0.4.1
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 28 Aug 2020 08:45:31 +0200
On Fri, 28 Aug 2020 at 00:48, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
I don’t use -j when doing clean/distclean/uninstall because they don’t normally take very long and getting the synchronization right in the build rules is tricky.
+1
Using parallel make for cleaning has caused issues for me a few times. Just don't.
Cheers,
~Ralph
Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
RE: Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Prev: Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
Next: Re: Opinions please, what should this database do Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Opinions please, what should this database do Johnson, Andrew N. via Core-talk
ANJ, 28 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
