2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Minor issue with base 7.0.4.1
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 27 Aug 2020 22:48:37 +0000
It probably depends on how long it takes to clean the various submodules, which depends on the your file-server, the age of the files it’s removing etc.
I don’t use -j when doing clean/distclean/uninstall because they don’t normally take very long and getting the synchronization right in the build rules is tricky. In your error, one of the subdirectories appears to have been slow to run and the Perl script it needed got removed by the uninstall target before the clean finished.
- Andrew
On Aug 27, 2020, at 5:38 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
I just did a fresh clone and I cannot reproduce the problem.  But it was definitely happening in my main working directory.  I don’t know if that is because I have a bunch of other architectures built there as well, or why it won’t fail on this fresh clone.
Sent: Thursday, August 27, 2020 4:58 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Hi Mark,
On Aug 26, 2020, at 5:42 PM, Mark Rivers via Core-talk <core-talk at aps.anl.gov> wrote:
I just updated base to 7.0.4.1
When I run “make –sj clean uninstall” on Centos 7 I get the following error message:
corvette:local/epics-devel/base-7.0.4>make -sj clean uninstall
Can't open perl script "/usr/local/epics-devel/base-7.0.4/bin/linux-x86_64/fullPathName.pl": No such file or directory
I think the command worked OK, but the error message is disconcerting.
Do the changes below fix that particular problem? It will probably behave differently on my machines, so I think you will have to test it to be sure:
diff --git a/configure/RULES_TOP b/configure/RULES_TOP
index b956839ec..9cac51c68 100644
--- a/configure/RULES_TOP
+++ b/configure/RULES_TOP
@@ -33,7 +33,7 @@ UNINSTALL_DIRS += $(INSTALL_INCLUDE) $(INSTALL_TEMPLATES) $(DIRECTORY_TARGETS)
 ifneq ($(INSTALL_LOCATION),$(TOP))
   UNINSTALL_DIRS += $(INSTALL_CONFIG)
 endif
-uninstallDirs:
+uninstallDirs: | clean
        $(RMDIR) $(UNINSTALL_DIRS)
   # Remove the bin and lib directories if they have no sub-directories
@@ -41,12 +41,12 @@ uninstallDirs:
 EMPTY_INSTALL_DIRS = \
     $(if $(wildcard $(INSTALL_LOCATION_BIN)/*),,$(INSTALL_LOCATION_BIN)) \
     $(if $(wildcard $(INSTALL_LOCATION_LIB)/*),,$(INSTALL_LOCATION_LIB))
-uninstall: archuninstall uninstallDirs
+uninstall: archuninstall uninstallDirs | clean
        $(RMDIR) $(EMPTY_INSTALL_DIRS)
 archuninstall: $(addprefix uninstall$(DIVIDER),$(BUILD_ARCHS))
-uninstall$(DIVIDER)%:
+uninstall$(DIVIDER)%: | clean
        $(RMDIR) $(addsuffix /$(subst uninstall$(DIVIDER),,$@), \
            $(INSTALL_LOCATION_BIN) $(INSTALL_LOCATION_LIB))
Those are order-only-prerequisites that tell GNUmake to wait for the ‘make clean’ to finish (if you’ve asked it to do that) before deleting the top-level dir’s. However o-o-p’s don’t always do what you might expect with phony targets.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Minor issue with base 7.0.4.1 Ralph Lange via Core-talk
Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
RE: Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Prev: RE: Minor issue with base 7.0.4.1 Mark Rivers via Core-talk
Next: Re: Minor issue with base 7.0.4.1 Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 28 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
