2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: caget working, but cainfo not ?
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 11 Sep 2020 10:12:24 +0200
On 11/09/20 09:09, Torsten Bögershausen via Core-talk wrote:
On 11/09/20 08:53, Ralph Lange via Core-talk wrote:
On Fri, 11 Sep 2020 at 07:40, Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
    Trying to find the box that is running the IOC ddidn't work:
    ~/shared_EEE/projects/epics/MCAG_setupMotionDemo.200109-base-7.0.3 $
    cainfo IOC:m1
    Channel connect timed out: 'IOC:m1' not found.
    But caget does work:
    caget IOC:m1
    IOC:m1                         6.01
    This is under MacOS, EPICS base 7.0.3.
    env | grep EPICS shows nothing special.
Unusual indeed.
Please try 'which' on the commands.
Maybe one of them is a 'convenience' script that sets the environment before running the binary from Base.
Cheers,
~Ralph
Side note:
The path is obfuscated,
(and I will reboot the machine, it's Friday)
~/somePath $ which caget
/Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/caget
~/somePath $ type caget
caget is hashed (/Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/caget)
~/somePath $ type cainfo
cainfo is hashed (/Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/cainfo)
~/somePath $ which cainfo
~/shared_EEE/somePath $
Thanks Ralph,
And here some more useless information...
- Rebooted the Mac
- Found the IOC on a linux machine,
  being once started in the background as part of an automated test.
Most probably we have settings like this:
EPICS_CA_ADDR_LIST=127.0.0.1
EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST EPICS_CA_AUTO_ADDR_LIST
Then we have a shell script to start the IOC, running
Base R7.0.4.1
The Linux box is connected to WLAN.
On the (rebooted) Mac (WLAN as well) the following
happens:
EPICS Base 7.0.3 (on the Mac):
  caget finds the PV sometimes, roughly 2-3 times of 10 tries
  cainfo does not find it.
EPICS Base  R3.15.5:
  caget fails always, and so does cainfo
I don't know if we should put more time on this issue ?
Re: caget working, but cainfo not ? Timo Korhonen via Core-talk
caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Re: caget working, but cainfo not ? Ralph Lange via Core-talk
Re: caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Prev: Re: caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Next: Re: caget working, but cainfo not ? Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 11 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
