2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: caget working, but cainfo not ?
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Timo Korhonen <Timo.Korhonen at ess.eu>, Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 11 Sep 2020 10:46:19 +0200
(Just to avoid confusion:
  netstat was run on the Linux box,
  pvget on the Mac)
On 11/09/20 10:44, Torsten Bögershausen via Core-talk wrote:
Hej Timo and all,
(Starting top-posting)
pvget gives me this:
  pvget -d IOC:m1
2020-09-11T10:35:47.820 Creating datagram socket from: 0.0.0.0:60988.
2020-09-11T10:35:47.821 Broadcast address #0: 192.168.xxx.255:5076. (not unicast) 2020-09-11T10:35:47.821 Setting up UDP for interface 192.168.xxx.79/255.255.255.0, broadcast 192.168.xxx.255, dest <none>.
2020-09-11T10:35:47.821 Creating datagram socket from: 192.168.xxx.79:5076.
2020-09-11T10:35:47.821 Creating datagram socket from: 192.168.xxx.255:5076.
2020-09-11T10:35:47.821 Creating datagram socket from: 224.0.0.128:5076.
2020-09-11T10:35:47.822 Local multicast enabled on 127.0.0.1/224.0.0.128:5076. 2020-09-11T10:35:47.822 Sending 52 bytes 0.0.0.0:60988 -> 192.168.xxx.255:5076. 2020-09-11T10:35:47.822 UDP Client Rx (52) 192.168.xxx.255:5076 <- 192.168.xxx.79:60988
Waiting...
2020-09-11T10:35:48.068 Sending 52 bytes 0.0.0.0:60988 -> 192.168.xxx.255:5076. 2020-09-11T10:35:48.068 UDP Client Rx (52) 192.168.xxx.255:5076 <- 192.168.xxx.79:60988 2020-09-11T10:35:48.555 Sending 52 bytes 0.0.0.0:60988 -> 192.168.xxx.255:5076. 2020-09-11T10:35:48.556 UDP Client Rx (52) 192.168.xxx.255:5076 <- 192.168.xxx.79:60988 2020-09-11T10:35:49.528 Sending 52 bytes 0.0.0.0:60988 -> 192.168.xxx.255:5076. 2020-09-11T10:35:49.528 UDP Client Rx (52) 192.168.xxx.255:5076 <- 192.168.xxx.79:60988 2020-09-11T10:35:51.473 Sending 52 bytes 0.0.0.0:60988 -> 192.168.xxx.255:5076. 2020-09-11T10:35:51.473 UDP Client Rx (52) 192.168.xxx.255:5076 <- 192.168.xxx.79:60988
Timeout
IOC:m1 2020-09-11T10:35:52.824 UDP socket 0.0.0.0:0 closed.
2020-09-11T10:35:52.824 UDP socket 192.168.xxx.79:5076 closed.
2020-09-11T10:35:52.824 UDP socket 192.168.xxx.255:5076 closed.
2020-09-11T10:35:52.825 UDP socket 224.0.0.128:5076 closed.
And this is from netstat, leaving out the "ESTABLISHED" sockets:
netstat -a -n -t | grep 506
tcp        0      0 0.0.0.0:5064            0.0.0.0:* LISTEN
netstat -a -n -u | grep 506
udp        0      0 0.0.0.0:5064            0.0.0.0:*
udp        0      0 0.0.0.0:5065            0.0.0.0:*
On 11/09/20 10:19, Timo Korhonen wrote:
Torsten, do you have pvget on your Mac? If yes, trying
pvget -d IOC:m1
could give you some hints on what is going on the network. (-d for debug).
Assuming your IOC is PVA-capable, that is.
Just my 2 cents __
Timo
On 11/09/20 10:12, "Core-talk on behalf of Torsten Bögershausen via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
     On 11/09/20 09:09, Torsten Bögershausen via Core-talk wrote:
     > On 11/09/20 08:53, Ralph Lange via Core-talk wrote:
     >> On Fri, 11 Sep 2020 at 07:40, Torsten Bögershausen via Core-talk
     >> <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
     >>     Trying to find the box that is running the IOC ddidn't work:
     >> ~/shared_EEE/projects/epics/MCAG_setupMotionDemo.200109-base-7.0.3 $
     >>     cainfo IOC:m1
     >>     Channel connect timed out: 'IOC:m1' not found.
     >>     But caget does work:
     >>     caget IOC:m1
     >>     IOC:m1                         6.01
     >>     This is under MacOS, EPICS base 7.0.3.
     >>     env | grep EPICS shows nothing special.
     >> Unusual indeed.
     >> Please try 'which' on the commands.
     >> Maybe one of them is a 'convenience' script that sets the environment
     >> before running the binary from Base.
     >> Cheers,
     >> ~Ralph
     > Side note:
     > The path is obfuscated,
     > (and I will reboot the machine, it's Friday)
     > ~/somePath $ which caget
     > /Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/caget
     > ~/somePath $ type caget
     > caget is hashed
     > (/Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/caget)
     > ~/somePath $ type cainfo
     > cainfo is hashed
     > (/Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/cainfo)
     > ~/somePath $ which cainfo
     > /Users/torstenbogershausen/somePath/epics/base/bin/darwin-x86/cainfo
     > ~/shared_EEE/somePath $
     Thanks Ralph,
     And here some more useless information...
     - Rebooted the Mac
     - Found the IOC on a linux machine,
        being once started in the background as part of an automated test.
     Most probably we have settings like this:
     EPICS_CA_ADDR_LIST=127.0.0.1
     EPICS_CA_AUTO_ADDR_LIST=NO
     export EPICS_CA_ADDR_LIST EPICS_CA_AUTO_ADDR_LIST
     Then we have a shell script to start the IOC, running
     Base R7.0.4.1
     The Linux box is connected to WLAN.
     On the (rebooted) Mac (WLAN as well) the following
     happens:
     EPICS Base 7.0.3 (on the Mac):
        caget finds the PV sometimes, roughly 2-3 times of 10 tries
        cainfo does not find it.
     EPICS Base  R3.15.5:
        caget fails always, and so does cainfo
     I don't know if we should put more time on this issue ?
Re: caget working, but cainfo not ? Johnson, Andrew N. via Core-talk
caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Re: caget working, but cainfo not ? Ralph Lange via Core-talk
Re: caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Re: caget working, but cainfo not ? Timo Korhonen via Core-talk
Prev: Re: caget working, but cainfo not ? Torsten Bögershausen via Core-talk
Next: Re: caget working, but cainfo not ? Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 14 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
