2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Compiler warning question
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 15 Sep 2020 22:30:27 +0000
With gcc 8.3.1 I am getting warnings in asyn that I don’t get with older versions of gcc (e.g. 4.8.5).
[epics@viper asyn]$ make -s
In function ‘setEnums.constprop’,
    inlined from ‘interruptCallbackEnumBi’ at ../../asyn/devEpics/devAsynInt32.c:759:5:
../../asyn/devEpics/devAsynInt32.c:444:25: warning: ‘strncpy’ forming offset [27, 51] is out of the bounds [0, 26] [-Warray-bounds]
         if (outStrings) strncpy(&outStrings[i*MAX_ENUM_STRING_SIZE], inStrings[i], MAX_ENUM_STRING_SIZE-1);
    inlined from ‘interruptCallbackEnumBo’ at ../../asyn/devEpics/devAsynInt32.c:773:5:
These warnings are when writing enum strings to the ONST, TWST, … fields of bo, bi, mbbo, and mbbi records.  The function is passed the address of the ZRST field, and computes the addresses of the other fields based on the knowledge of how large each field is (26 bytes) and that the fields are consecutive.  The compiler now is smart enough to say that the array I passed is actually only 26 bytes and so complains about writing to the other fields.
Is there a way to fix this via a cast to avoid that warning?
Re: Compiler warning question Torsten Bögershausen via Core-talk
Prev: Re: caget working, but cainfo not ? Johnson, Andrew N. via Core-talk
Next: Re: Compiler warning question Torsten Bögershausen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
ANJ, 16 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
