2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Compiler warning question
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 16 Sep 2020 08:40:51 +0200
Hej Mark,
it seams as if new compilers don't like strncpy() any more ?
The problem that strncpy() solves against strcpy() is that
we don't everwrite memory.
The problem that strncpy() does not solve is to make sure that
there is always a terminating NUL byte.
The BSD world has invented strlcpy() for this.
One alternative would be to simply use memcpy(), but one count less,
leaving place for the '\0' byte, and then adding a '\0' at the reserved
space.
The following works for me (gcc 8.3 Debian)
diff --git a/asyn/devEpics/devAsynInt32.c b/asyn/devEpics/devAsynInt32.c
index 52a1dacd..8669bf63 100644
--- a/asyn/devEpics/devAsynInt32.c
+++ b/asyn/devEpics/devAsynInt32.c
@@ -427,7 +427,14 @@ static void setEnums(char *outStrings, int *outVals, epicsEnum16 *outSeverities,
         if (outSeverities) outSeverities[i] = 0;
     for (i=0; (i<numIn && i<numOut); i++) {
- if (outStrings) strncpy(&outStrings[i*MAX_ENUM_STRING_SIZE], inStrings[i], MAX_ENUM_STRING_SIZE);
+        if (outStrings) {
+            /* memcpy nearly all, leave one byte for '\0' */
+            memcpy(&outStrings[i*MAX_ENUM_STRING_SIZE],
+                   inStrings[i],
+                   MAX_ENUM_STRING_SIZE-1);
+            /* make sure that we have a terminating '\0' */
+ outStrings[i*MAX_ENUM_STRING_SIZE + MAX_ENUM_STRING_SIZE-1] = '\0';
         if (outVals) outVals[i] = inVals[i];
         if (outSeverities) outSeverities[i] = inSeverities[i];
On 9/16/20 12:30 AM, Mark Rivers via Core-talk wrote:
With gcc 8.3.1 I am getting warnings in asyn that I don’t get with older versions of gcc (e.g. 4.8.5).
[epics@viper asyn]$ make -s
In function ‘setEnums.constprop’,
    inlined from ‘interruptCallbackEnumBi’ at ../../asyn/devEpics/devAsynInt32.c:759:5:
../../asyn/devEpics/devAsynInt32.c:444:25: warning: ‘strncpy’ forming offset [27, 51] is out of the bounds [0, 26] [-Warray-bounds]
         if (outStrings) strncpy(&outStrings[i*MAX_ENUM_STRING_SIZE], inStrings[i], MAX_ENUM_STRING_SIZE-1);
    inlined from ‘interruptCallbackEnumBo’ at ../../asyn/devEpics/devAsynInt32.c:773:5:
These warnings are when writing enum strings to the ONST, TWST, … fields of bo, bi, mbbo, and mbbi records.  The function is passed the address of the ZRST field, and computes the addresses of the other fields based on the knowledge of how large each field is (26 bytes) and that the fields are consecutive.  The compiler now is smart enough to say that the array I passed is actually only 26 bytes and so complains about writing to the other fields.
Is there a way to fix this via a cast to avoid that warning?
Re: Compiler warning question Ralph Lange via Core-talk
Re: Compiler warning question Benjamin Franksen via Core-talk
RE: Compiler warning question Mark Rivers via Core-talk
Prev: Compiler warning question Mark Rivers via Core-talk
Next: Jenkins build is back to stable : epics-7.0 » linux32 #259 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Compiler warning question Ralph Lange via Core-talk
ANJ, 19 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
