I have decided to following Torsten's suggestion of using memcpy() rather than strncpy(). This avoid the compiler warning, though next year the compiler may get smarter and see through this as well.
- if (outStrings) strncpy(&outStrings[i*MAX_ENUM_STRING_SIZE], inStrings[i], MAX_ENUM_STRING_SIZE);
+ if (outStrings) {
+ size_t len = strlen(inStrings[i]);
+ if (len > MAX_ENUM_STRING_SIZE-1) len = MAX_ENUM_STRING_SIZE-1;
+ memcpy(&outStrings[i*MAX_ENUM_STRING_SIZE], inStrings[i], len);
+ outStrings[i*MAX_ENUM_STRING_SIZE + len] = '\0';
My fix is a little different from Torsten's, because mine should be safe against inStrings[i] being smaller than MAX_NUM_STRING_SIZE.
-----Original Message-----
From: Torsten Bögershausen <torsten.bogershausen at ess.eu>
Sent: Wednesday, September 16, 2020 1:41 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; EPICS core-talk <core-talk at aps.anl.gov>
Subject: Re: Compiler warning question
Hej Mark,
it seams as if new compilers don't like strncpy() any more ?
The problem that strncpy() solves against strcpy() is that we don't everwrite memory.
The problem that strncpy() does not solve is to make sure that there is always a terminating NUL byte.
The BSD world has invented strlcpy() for this.
One alternative would be to simply use memcpy(), but one count less, leaving place for the '\0' byte, and then adding a '\0' at the reserved space.
The following works for me (gcc 8.3 Debian)
diff --git a/asyn/devEpics/devAsynInt32.c b/asyn/devEpics/devAsynInt32.c index 52a1dacd..8669bf63 100644
--- a/asyn/devEpics/devAsynInt32.c
+++ b/asyn/devEpics/devAsynInt32.c
@@ -427,7 +427,14 @@ static void setEnums(char *outStrings, int *outVals, epicsEnum16 *outSeverities,
if (outSeverities) outSeverities[i] = 0;
for (i=0; (i<numIn && i<numOut); i++) {
+ if (outStrings) {
+ /* memcpy nearly all, leave one byte for '\0' */
+ inStrings[i],
+ MAX_ENUM_STRING_SIZE-1);
+ /* make sure that we have a terminating '\0' */
+ outStrings[i*MAX_ENUM_STRING_SIZE + MAX_ENUM_STRING_SIZE-1]
= '\0';
if (outVals) outVals[i] = inVals[i];
if (outSeverities) outSeverities[i] = inSeverities[i];
On 9/16/20 12:30 AM, Mark Rivers via Core-talk wrote:
> With gcc 8.3.1 I am getting warnings in asyn that I don't get with
> older versions of gcc (e.g. 4.8.5).
> [epics@viper asyn]$ make -s
> In function 'setEnums.constprop',
> inlined from 'interruptCallbackEnumBi' at
> ../../asyn/devEpics/devAsynInt32.c:759:5:
> ../../asyn/devEpics/devAsynInt32.c:444:25: warning: 'strncpy' forming
> offset [27, 51] is out of the bounds [0, 26] [-Warray-bounds]
> inStrings[i], MAX_ENUM_STRING_SIZE-1);
> inlined from 'interruptCallbackEnumBo' at
> ../../asyn/devEpics/devAsynInt32.c:773:5:
> These warnings are when writing enum strings to the ONST, TWST, .
> fields of bo, bi, mbbo, and mbbi records. The function is passed the
> address of the ZRST field, and computes the addresses of the other
> fields based on the knowledge of how large each field is (26 bytes)
> and that the fields are consecutive. The compiler now is smart enough
> to say that the array I passed is actually only 26 bytes and so
> complains about writing to the other fields.
> Is there a way to fix this via a cast to avoid that warning?
> Mark
- Compiler warning question Mark Rivers via Core-talk
- Re: Compiler warning question Torsten Bögershausen via Core-talk
[Bug 1896295] Re: WIN32: IOC scan loops hang mdavidsaver via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
<2020>
2025
2026
Re: Compiler warning question Benjamin Franksen via Core-talk
Build failed: EPICS Base 7 base-7.0-87 AppVeyor via Core-talk
<2020>
2025
2026
