2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0
From: Freddie Akeroyd via Core-talk <core-talk at aps.anl.gov>
To: mp+391018 at code.launchpad.net
Date: Sat, 19 Sep 2020 14:25:31 -0000
@Michael I guess you mean throw an exception rather than a build failure as GetTickCount() is only a fallback if there is a problem using QueryPerformanceCounter()? It looks like QueryPerformanceCounter() is guaranteed to be available on Windows XP and later, so we could drop GetTickCount() entirely if we only support XP and higher. There is some discussion on https://docs.microsoft.com/en-us/windows/win32/sysinfo/acquiring-high-resolution-time-stamps about consistency of performance counters across multiple cores, but I think this only applies to Windows XP and earlier. Do we need to provide an option to allow the user to specify an alternative to QueryPerformanceCounter() (which on XP may mean we would have to monitor a rollover of GetTickCount()) or should we only support and implement  QueryPerformanceCounter() as the basis for monotonic time?
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/391018
Your team EPICS Core Developers is requested to review the proposed merge of ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0.
[Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Prev: RE: Compiler warning question Mark Rivers via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:fix_win32_monotonic_time into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 19 Sep 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
