2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1899697] [NEW] PHAS is not always respected when SCAN=Event
From: Bruno Martins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 13 Oct 2020 20:50:34 -0000
Public bug reported:
There is a bug when adding records to an Event scan list. Adding a
record to an event scan list with a lower PHAS than any other previously
added record will end up putting it at the *end* of the list (not at the
beginning). Triggering the bug:
    $ cat test.db
    record(ai, "SECOND") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "1") }
    record(ai, "FIRST")  { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "0") }
    record(ai, "THIRD")  { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "2") }
    $ softIoc -d test.db
    Starting iocInit
    ## EPICS R3.15.8-1+0~20200608134952.18+debian10~1.gbp3c2d35
    ## EPICS Base built Jun  8 2020
    epics> scanpel
    Event "E"
     Priority Low
        SECOND
        FIRST
        THIRD
    epics>
The expected order is FIRST, SECOND, THIRD. I attached a patch (for
3.15.8) that I think fixes the issue. I found it in 3.15.8 but it seems
to affect 7.0 series as well.
** Affects: epics-base
     Importance: Undecided
         Status: New
** Patch added: "fix-event-scan-list.patch"
   https://bugs.launchpad.net/bugs/1899697/+attachment/5421868/+files/fix-event-scan-list.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
Title:
Status in EPICS Base:
  New
Bug description:
  previously added record will end up putting it at the *end* of the
  list (not at the beginning). Triggering the bug:
      $ cat test.db
      Starting iocInit
      epics> scanpel
      Event "E"
       Priority Low
          SECOND
          FIRST
          THIRD
      epics>
  seems to affect 7.0 series as well.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1899697/+subscriptions
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Launchpad Bug Tracker via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Dirk Zimoch via Core-talk
Prev: [Bug 1882120] Re: EPICS Open License - add to SPDX License List? Andrew Johnson via Core-talk
Next: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Build failed: EPICS Base 7 base-7.0-90 AppVeyor via Core-talk
ANJ, 20 Oct 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
