Oops! Accepted by inspecting the code, thanks for the fix! Note that
this won't just affect SCAN==Event, all the scan types respect PHAS and
could be affected.
This definitely needs to be fixed on the 3.15 branch and merged up.
It ought to be possible to combine the two calls to ellInsert() in that
routine. Remove the first call completely and the leading if() statement
in Bruno's patch and use (ptemp ? &ptemp->node : NULL) for the second
argument.
Bruno's patch also fixes a proto-bug in that the second argument to the
current ellAdd() call assumes that offsetof(scan_element, node)==0. I
thought we'd fixed most of those but we missed that one and in the
similar ellDelete() call lower down - replace (void *)pse with
&pse->node.
It would be nice to add some tests to dbScanTest.c for this and similar
scan-list manipulations, but that exists only on the 7.0 branch so it
would have to be done separately. Codeathon task?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1899697
Title:
PHAS is not always respected when SCAN=Event
Status in EPICS Base:
Triaged
Status in EPICS Base 3.15 series:
Triaged
Status in EPICS Base 7.0 series:
Triaged
Bug description:
There is a bug when adding records to an Event scan list. Adding a
record to an event scan list with a lower PHAS than any other
previously added record will end up putting it at the *end* of the
list (not at the beginning). Triggering the bug:
$ cat test.db
record(ai, "SECOND") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "1") }
record(ai, "FIRST") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "0") }
record(ai, "THIRD") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "2") }
$ softIoc -d test.db
Starting iocInit
## EPICS R3.15.8-1+0~20200608134952.18+debian10~1.gbp3c2d35
## EPICS Base built Jun 8 2020
epics> scanpel
Event "E"
Priority Low
SECOND
FIRST
THIRD
epics>
The expected order is FIRST, SECOND, THIRD. I attached a patch (for
3.15.8) that I think fixes the issue. I found it in 3.15.8 but it
seems to affect 7.0 series as well.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1899697/+subscriptions
- [Bug 1899697] [NEW] PHAS is not always respected when SCAN=Event Bruno Martins via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
<2020>
2025
2026
<2020>
2025
2026
