2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event
From: Launchpad Bug Tracker via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 13 Oct 2020 22:40:18 -0000
** Merge proposal linked:
   https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/392190
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1899697
Title:
Status in EPICS Base:
  Triaged
Status in EPICS Base 3.15 series:
  Triaged
Status in EPICS Base 7.0 series:
  Triaged
Bug description:
  There is a bug when adding records to an Event scan list. Adding a
  record to an event scan list with a lower PHAS than any other
  previously added record will end up putting it at the *end* of the
  list (not at the beginning). Triggering the bug:
      $ cat test.db
      record(ai, "SECOND") { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "1") }
      record(ai, "FIRST")  { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "0") }
      record(ai, "THIRD")  { field(EVNT, "E") field(SCAN, "Event") field(PHAS, "2") }
      $ softIoc -d test.db
      Starting iocInit
      ## EPICS R3.15.8-1+0~20200608134952.18+debian10~1.gbp3c2d35
      ## EPICS Base built Jun  8 2020
      epics> scanpel
      Event "E"
       Priority Low
          SECOND
          FIRST
          THIRD
      epics>
  The expected order is FIRST, SECOND, THIRD. I attached a patch (for
  3.15.8) that I think fixes the issue. I found it in 3.15.8 but it
  seems to affect 7.0 series as well.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1899697/+subscriptions
[Bug 1899697] [NEW] PHAS is not always respected when SCAN=Event Bruno Martins via Core-talk
Prev: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
Next: [Merge] ~info-martin-konrad/epics-base:fix-wrong-order-phas into epics-base:3.15 Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
ANJ, 13 Oct 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
