2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Merge] ~info-martin-konrad/epics-base:fix-wrong-order-phas into epics-base:3.15
From: Martin Konrad via Core-talk <core-talk at aps.anl.gov>
To: mp+392190 at code.launchpad.net
Date: Tue, 13 Oct 2020 22:40:39 -0000
Martin Konrad has proposed merging ~info-martin-konrad/epics-base:fix-wrong-order-phas into epics-base:3.15.
Requested reviews:
  Andrew Johnson (anj)
Related bugs:
  Bug #1899697 in EPICS Base: "PHAS is not always respected when SCAN=Event"
  https://bugs.launchpad.net/epics-base/+bug/1899697
For more details, see:
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/392190
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
diff --git a/src/ioc/db/dbScan.c b/src/ioc/db/dbScan.c
index dd283f7..5fc264d 100644
--- a/src/ioc/db/dbScan.c
+++ b/src/ioc/db/dbScan.c
@@ -992,13 +992,10 @@ static void addToList(struct dbCommon *precord, scan_list *psl)
     pse->pscan_list = psl;
     ptemp = (scan_element *)ellLast(&psl->list);
     while (ptemp) {
-        if (ptemp->precord->phas <= precord->phas) {
-            ellInsert(&psl->list, &ptemp->node, &pse->node);
-            break;
+        if (ptemp->precord->phas <= precord->phas) break;
         ptemp = (scan_element *)ellPrevious(&ptemp->node);
-    if (ptemp == NULL) ellAdd(&psl->list, (void *)pse);
+    ellInsert(&psl->list, (ptemp ? &ptemp->node : NULL), &pse->node);
     psl->modified = TRUE;
     epicsMutexUnlock(psl->lock);
@@ -1024,7 +1021,7 @@ static void deleteFromList(struct dbCommon *precord, scan_list *psl)
         return;
     pse->pscan_list = NULL;
-    ellDelete(&psl->list, (void *)pse);
+    ellDelete(&psl->list, &pse->node);
[Merge] ~info-martin-konrad/epics-base:fix-wrong-order-phas into epics-base:3.15 noreply--- via Core-talk
Prev: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Launchpad Bug Tracker via Core-talk
Next: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Martin Konrad via Core-talk
Next: [Merge] ~info-martin-konrad/epics-base:fix-wrong-order-phas into epics-base:3.15 noreply--- via Core-talk
ANJ, 22 Oct 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
