2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Arithmetic - test with qoriq
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 15 Jan 2021 18:49:46 +0000
On Jan 15, 2021, at 10:28 AM, Heinz Junkes via Core-talk <core-talk at aps.anl.gov> wrote:
I now have epics on RTEMS5 running quite reasonably on the qoriq system (MVME2500).
I see problems with the arithmetic (even without optimization):
At least some of these failures look more like problems in the compiler than on the device itself:
not ok 18 - Inf
# Expected result is 1.79769e+308, actually got inf
       Double inf
not ok 19 - Infinity
       Double inf
not ok 20 - NaN
# Expected result is 1.79769e+308, actually got nan
       Double nan
The above expected results were calculated by the compiler and are wrong, whereas the calc _expression_ is actually returning the right result.
not ok 38 - -Inf
# Expected result is -1.79769e+308, actually got -inf
       Double inf
       UNARY_NEG
As above.
not ok 57 - finite(Inf)
# Expected result is 1, actually got 0
       Double inf
       FINITE, 1 arg(s)
Hmm, no the compiler is wrong again, and for the next 2:
not ok 58 - finite(-Inf)
       Double inf
       UNARY_NEG
       FINITE, 1 arg(s)
not ok 59 - finite(NaN)
       Double nan
       FINITE, 1 arg(s)
For these finite() tests we provide the expected result, which is why they pass:
ok 60 - finite(0,1,2)
ok 69 - finite(-Inf,1,2)
These are all compiler errors:
not ok 93 - MAX( 1., Inf)
       Integer 1 (0x1)
       Double inf
       MAX, 2 arg(s)
not ok 95 - MAX( 1., NaN)
       Integer 1 (0x1)
       Double nan
       MAX, 2 arg(s)
not ok 96 - MAX( Inf, 1.)
       Double inf
       Integer 1 (0x1)
       MAX, 2 arg(s)
not ok 98 - MAX( NaN, 1.)
       Double nan
       Integer 1 (0x1)
       MAX, 2 arg(s)
not ok 105 - MAX( 1., 2., Inf)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double inf
       MAX, 3 arg(s)
not ok 107 - MAX( 1., 2., NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double nan
       MAX, 3 arg(s)
not ok 108 - MAX( 1., Inf,2.)
       Integer 1 (0x1)
       Double inf
       Integer 2 (0x2)
       MAX, 3 arg(s)
not ok 110 - MAX( 1., NaN,2.)
       Integer 1 (0x1)
       Double nan
       Integer 2 (0x2)
       MAX, 3 arg(s)
not ok 111 - MAX( Inf, 1.,2.)
       Double inf
       Integer 1 (0x1)
       Integer 2 (0x2)
       MAX, 3 arg(s)
not ok 113 - MAX( NaN, 1.,2.)
       Double nan
       Integer 1 (0x1)
       Integer 2 (0x2)
       MAX, 3 arg(s)
not ok 118 - MAX( 1., 2., 3.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double nan
       MAX, 4 arg(s)
not ok 119 - MAX( 1., 2.,NaN, 3.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double nan
       Integer 3 (0x3)
       MAX, 4 arg(s)
not ok 120 - MAX( 1.,NaN, 3., 2.)
       Integer 1 (0x1)
       Double nan
       Integer 3 (0x3)
       Integer 2 (0x2)
       MAX, 4 arg(s)
not ok 121 - MAX(NaN, 2., 3., 1.)
       Double nan
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 1 (0x1)
       MAX, 4 arg(s)
not ok 127 - MAX( 1., 2., 3., 4.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Double nan
       MAX, 5 arg(s)
not ok 128 - MAX( 1., 2., 3.,NaN, 4.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double nan
       Integer 4 (0x4)
       MAX, 5 arg(s)
not ok 129 - MAX( 1., 2.,NaN, 4., 3.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double nan
       Integer 4 (0x4)
       Integer 3 (0x3)
       MAX, 5 arg(s)
not ok 130 - MAX( 1.,NaN, 3., 4., 2.)
       Integer 1 (0x1)
       Double nan
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 2 (0x2)
       MAX, 5 arg(s)
not ok 131 - MAX(NaN, 2., 3., 4., 1.)
       Double nan
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 1 (0x1)
       MAX, 5 arg(s)
not ok 138 - MAX( 1., 2., 3., 4., 5.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Double nan
       MAX, 6 arg(s)
not ok 139 - MAX( 1., 2., 3., 4.,NaN, 5.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Double nan
       Integer 5 (0x5)
       MAX, 6 arg(s)
not ok 140 - MAX( 1., 2., 3.,NaN, 5., 4.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double nan
       Integer 5 (0x5)
       Integer 4 (0x4)
       MAX, 6 arg(s)
not ok 141 - MAX( 1., 2.,NaN, 4., 5., 3.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double nan
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 3 (0x3)
       MAX, 6 arg(s)
not ok 142 - MAX( 1.,NaN, 3., 4., 5., 2.)
       Integer 1 (0x1)
       Double nan
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 2 (0x2)
       MAX, 6 arg(s)
not ok 143 - MAX(NaN, 2., 3., 4., 5., 1.)
       Double nan
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 1 (0x1)
       MAX, 6 arg(s)
not ok 144 - MAX( 1., 2., 3., 4., 5.,Inf)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Double inf
       MAX, 6 arg(s)
not ok 145 - MAX( 1., 2., 3., 4.,Inf, 5.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Double inf
       Integer 5 (0x5)
       MAX, 6 arg(s)
not ok 146 - MAX( 1., 2., 3.,Inf, 5., 4.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double inf
       Integer 5 (0x5)
       Integer 4 (0x4)
       MAX, 6 arg(s)
not ok 147 - MAX( 1., 2.,Inf, 4., 5., 3.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double inf
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 3 (0x3)
       MAX, 6 arg(s)
not ok 148 - MAX( 1.,Inf, 3., 4., 5., 2.)
       Integer 1 (0x1)
       Double inf
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 2 (0x2)
       MAX, 6 arg(s)
not ok 149 - MAX(Inf, 2., 3., 4., 5., 1.)
       Double inf
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 1 (0x1)
       MAX, 6 arg(s)
not ok 156 - MIN(1.,-Inf)
       Integer 1 (0x1)
       Double inf
       UNARY_NEG
       MIN, 2 arg(s)
This and some of the tests below imply that when the compiler does the math it's handling NaN as though it’s the value 1.79769e+308.
not ok 157 - MIN(1.,NaN)
# Expected result is 1, actually got nan
       Integer 1 (0x1)
       Double nan
       MIN, 2 arg(s)
The expected result there ought to be NaN, not 1.
Given the previous result though this test pass surprises me:
ok 158 - MIN(NaN,1.)
The result of the above should have been NaN, but the compiler’s expected result would have been 1.0. Can you try adding this line to the epicsCalcTest.cpp file and see what it gives?
    testCalc("MIN(NaN,1.)", NaN);
Compiler errors in the expected result:
not ok 166 - MIN( 1., 2.,-Inf)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double inf
       UNARY_NEG
       MIN, 3 arg(s)
not ok 167 - MIN( 1., 2., NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double nan
       MIN, 3 arg(s)
not ok 169 - MIN( 1.,-Inf,2.)
       Integer 1 (0x1)
       Double inf
       UNARY_NEG
       Integer 2 (0x2)
       MIN, 3 arg(s)
not ok 172 - MIN(-Inf, 1.,2.)
       Double inf
       UNARY_NEG
       Integer 1 (0x1)
       Integer 2 (0x2)
       MIN, 3 arg(s)
not ok 178 - MIN( 1., 2., 3.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double nan
       MIN, 4 arg(s)
not ok 187 - MIN( 1., 2., 3., 4.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Double nan
       MIN, 5 arg(s)
not ok 198 - MIN( 1., 2., 3., 4., 5.,NaN)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Double nan
       MIN, 6 arg(s)
not ok 204 - MIN( 1., 2., 3., 4., 5.,-Inf)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Double inf
       UNARY_NEG
       MIN, 6 arg(s)
not ok 205 - MIN( 1., 2., 3., 4.,-Inf, 5.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Double inf
       UNARY_NEG
       Integer 5 (0x5)
       MIN, 6 arg(s)
not ok 206 - MIN( 1., 2., 3.,-Inf, 5., 4.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Integer 3 (0x3)
       Double inf
       UNARY_NEG
       Integer 5 (0x5)
       Integer 4 (0x4)
       MIN, 6 arg(s)
not ok 207 - MIN( 1., 2.,-Inf, 4., 5., 3.)
       Integer 1 (0x1)
       Integer 2 (0x2)
       Double inf
       UNARY_NEG
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 3 (0x3)
       MIN, 6 arg(s)
not ok 208 - MIN( 1.,-Inf, 3., 4., 5., 2.)
       Integer 1 (0x1)
       Double inf
       UNARY_NEG
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 2 (0x2)
       MIN, 6 arg(s)
not ok 209 - MIN(-Inf, 2., 3., 4., 5., 1.)
       Double inf
       UNARY_NEG
       Integer 2 (0x2)
       Integer 3 (0x3)
       Integer 4 (0x4)
       Integer 5 (0x5)
       Integer 1 (0x1)
       MIN, 6 arg(s)
not ok 236 - Inf != NaN
# Expected result is 0, actually got 1
       Double inf
       Double nan
       NOT_EQ
So the compiler thinks Inf == NaN?
not ok 242 - NaN != Inf
       Double nan
       Double inf
       NOT_EQ
At least it’s consistent.
These expected results are fun:
not ok 263 - Inf * Inf
# Expected result is 3.40282e+38, actually got 1.79769e+308
       Double inf
       Double inf
       MULT
not ok 264 - Inf * -Inf
# Expected result is -3.40282e+38, actually got -1.79769e+308
       Double inf
       Double inf
       UNARY_NEG
       MULT
not ok 265 - Inf * NaN
       Double inf
       Double nan
       MULT
not ok 267 - -Inf * Inf
       Double inf
       UNARY_NEG
       Double inf
       MULT
not ok 268 - -Inf * -Inf
       Double inf
       UNARY_NEG
       Double inf
       UNARY_NEG
       MULT
not ok 269 - -Inf * NaN
       Double inf
       UNARY_NEG
       Double nan
       MULT
not ok 271 - NaN * Inf
       Double nan
       Double inf
       MULT
not ok 272 - NaN * -Inf
       Double nan
       Double inf
       UNARY_NEG
       MULT
not ok 273 - NaN * NaN
       Double nan
       Double nan
       MULT
not ok 284 - Inf + Inf
       Double inf
       Double inf
       ADD
not ok 285 - Inf + -Inf
       Double inf
       Double inf
       UNARY_NEG
       ADD
not ok 286 - Inf + NaN
       Double inf
       Double nan
       ADD
not ok 288 - -Inf + Inf
# Expected result is 3.40282e+38, actually got -1.79769e+308
       Double inf
       UNARY_NEG
       Double inf
       ADD
not ok 289 - -Inf + -Inf
       Double inf
       UNARY_NEG
       Double inf
       UNARY_NEG
       ADD
not ok 290 - -Inf + NaN
       Double inf
       UNARY_NEG
       Double nan
       ADD
not ok 292 - NaN + Inf
       Double nan
       Double inf
       ADD
not ok 293 - NaN + -Inf
       Double nan
       Double inf
       UNARY_NEG
       ADD
not ok 294 - NaN + NaN
       Double nan
       Double nan
       ADD
not ok 301 - Inf - Inf
       Double inf
       Double inf
       SUB
not ok 302 - Inf - -Inf
       Double inf
       Double inf
       UNARY_NEG
       SUB
not ok 303 - Inf - NaN
       Double inf
       Double nan
       SUB
not ok 305 - -Inf - Inf
       Double inf
       UNARY_NEG
       Double inf
       SUB
not ok 306 - -Inf - -Inf
       Double inf
       UNARY_NEG
       Double inf
       UNARY_NEG
       SUB
not ok 307 - -Inf - NaN
       Double inf
       UNARY_NEG
       Double nan
       SUB
not ok 309 - NaN - Inf
       Double nan
       Double inf
       SUB
not ok 310 - NaN - -Inf
       Double nan
       Double inf
       UNARY_NEG
       SUB
not ok 311 - NaN - NaN
       Double nan
       Double nan
       SUB
not ok 339 - Inf < NaN
       Double inf
       Double nan
       LESS_THAN
Here the compiler’s expected result was actually right (confirmed on Darwin) and the actual result is wrong. Try adding this line to epicsCalcTest.cpp to confirm:
    testCalc("Inf < NaN", 0);
not ok 366 - NaN <= Inf
       Double nan
       Double inf
       LESS_OR_EQ
Another surprise there, please try adding this:
    testCalc("NaN <= Inf", 0);
not ok 383 - Inf == NaN
       Double inf
       Double nan
       EQUAL
Yes, the compiler does think Inf == NaN!
not ok 389 - NaN == Inf
       Double nan
       Double inf
       EQUAL
Both ways round too!
not ok 408 - NaN > Inf
       Double nan
       Double inf
       GR_THAN
The compiler is being consistent, but any _expression_ involving a NaN should return 0. Try this to confirm:
    testCalc("NaN > Inf", 0);
not ok 421 - Inf >= NaN
       Double inf
       Double nan
       GR_OR_EQ
And this:
    testCalc("Inf >= NaN", 0);
So there are problems in the compiler, but the run-time doesn’t seem to be 100% right either. The compiler issues should be easily extracted into simple C/C++ code and reported (to the RTEMS guys first?) if someone wants to work on that...
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Arithmetic - test with qoriq Michael Davidsaver via Core-talk
Arithmetic - test with qoriq Heinz Junkes via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #912 Jenkins EPICS PSI via Core-talk
Next: Re: Arithmetic - test with qoriq Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Arithmetic - test with qoriq Ralph Lange via Core-talk
ANJ, 15 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
