2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Arithmetic - test with qoriq
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 15 Jan 2021 11:00:27 -0800
On 1/15/21 10:49 AM, Johnson, Andrew N. via Core-talk wrote:
> On Jan 15, 2021, at 10:28 AM, Heinz Junkes via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>> I now have epics on RTEMS5 running quite reasonably on the qoriq system (MVME2500).
>> I see problems with the arithmetic (even without optimization):
> At least some of these failures look more like problems in the compiler than on the device itself:
>> not ok 18 - Inf
>> # Expected result is 1.79769e+308, actually got inf
>>        Double inf
>> not ok 19 - Infinity
>>        Double inf
>> not ok 20 - NaN
>> # Expected result is 1.79769e+308, actually got nan
>>        Double nan
> The above expected results were calculated by the compiler and are wrong, whereas the calc expression is actually returning the right result.
From a quick look at math.h with RTEMS 5.1 i386 (really newlib?)
the INFINITY macro (used in epicsMath.cpp to initialize epicsINF)
should expand to a __builtin_inff().
It might be worth making sure this is used.  (as opposed to
our makeINF() in epicsMathc.cpp)  Also to see what the
builtin really is expanding to for this powerpc target.
>> not ok 38 - -Inf
>> # Expected result is -1.79769e+308, actually got -inf
>>        Double inf
>>        UNARY_NEG
> As above.
>> not ok 57 - finite(Inf)
>> # Expected result is 1, actually got 0
>>        Double inf
>>        FINITE, 1 arg(s)
> Hmm, no the compiler is wrong again, and for the next 2:
>> not ok 58 - finite(-Inf)
>>        Double inf
>>        UNARY_NEG
>>        FINITE, 1 arg(s)
>> not ok 59 - finite(NaN)
>>        Double nan
>>        FINITE, 1 arg(s)
> For these finite() tests we provide the expected result, which is why they pass:
>> ok 60 - finite(0,1,2)
>> ok 69 - finite(-Inf,1,2)
> These are all compiler errors:
>> not ok 93 - MAX( 1., Inf)
>>        Integer 1 (0x1)
>>        Double inf
>>        MAX, 2 arg(s)
>> not ok 95 - MAX( 1., NaN)
>>        Integer 1 (0x1)
>>        Double nan
>>        MAX, 2 arg(s)
>> not ok 96 - MAX( Inf, 1.)
>>        Double inf
>>        Integer 1 (0x1)
>>        MAX, 2 arg(s)
>> not ok 98 - MAX( NaN, 1.)
>>        Double nan
>>        Integer 1 (0x1)
>>        MAX, 2 arg(s)
>> not ok 105 - MAX( 1., 2., Inf)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double inf
>>        MAX, 3 arg(s)
>> not ok 107 - MAX( 1., 2., NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double nan
>>        MAX, 3 arg(s)
>> not ok 108 - MAX( 1., Inf,2.)
>>        Integer 1 (0x1)
>>        Double inf
>>        Integer 2 (0x2)
>>        MAX, 3 arg(s)
>> not ok 110 - MAX( 1., NaN,2.)
>>        Integer 1 (0x1)
>>        Double nan
>>        Integer 2 (0x2)
>>        MAX, 3 arg(s)
>> not ok 111 - MAX( Inf, 1.,2.)
>>        Double inf
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        MAX, 3 arg(s)
>> not ok 113 - MAX( NaN, 1.,2.)
>>        Double nan
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        MAX, 3 arg(s)
>> not ok 118 - MAX( 1., 2., 3.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double nan
>>        MAX, 4 arg(s)
>> not ok 119 - MAX( 1., 2.,NaN, 3.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double nan
>>        Integer 3 (0x3)
>>        MAX, 4 arg(s)
>> not ok 120 - MAX( 1.,NaN, 3., 2.)
>>        Integer 1 (0x1)
>>        Double nan
>>        Integer 3 (0x3)
>>        Integer 2 (0x2)
>>        MAX, 4 arg(s)
>> not ok 121 - MAX(NaN, 2., 3., 1.)
>>        Double nan
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 1 (0x1)
>>        MAX, 4 arg(s)
>> not ok 127 - MAX( 1., 2., 3., 4.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Double nan
>>        MAX, 5 arg(s)
>> not ok 128 - MAX( 1., 2., 3.,NaN, 4.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double nan
>>        Integer 4 (0x4)
>>        MAX, 5 arg(s)
>> not ok 129 - MAX( 1., 2.,NaN, 4., 3.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double nan
>>        Integer 4 (0x4)
>>        Integer 3 (0x3)
>>        MAX, 5 arg(s)
>> not ok 130 - MAX( 1.,NaN, 3., 4., 2.)
>>        Integer 1 (0x1)
>>        Double nan
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 2 (0x2)
>>        MAX, 5 arg(s)
>> not ok 131 - MAX(NaN, 2., 3., 4., 1.)
>>        Double nan
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 1 (0x1)
>>        MAX, 5 arg(s)
>> not ok 138 - MAX( 1., 2., 3., 4., 5.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Double nan
>>        MAX, 6 arg(s)
>> not ok 139 - MAX( 1., 2., 3., 4.,NaN, 5.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Double nan
>>        Integer 5 (0x5)
>>        MAX, 6 arg(s)
>> not ok 140 - MAX( 1., 2., 3.,NaN, 5., 4.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double nan
>>        Integer 5 (0x5)
>>        Integer 4 (0x4)
>>        MAX, 6 arg(s)
>> not ok 141 - MAX( 1., 2.,NaN, 4., 5., 3.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double nan
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 3 (0x3)
>>        MAX, 6 arg(s)
>> not ok 142 - MAX( 1.,NaN, 3., 4., 5., 2.)
>>        Integer 1 (0x1)
>>        Double nan
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 2 (0x2)
>>        MAX, 6 arg(s)
>> not ok 143 - MAX(NaN, 2., 3., 4., 5., 1.)
>>        Double nan
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 1 (0x1)
>>        MAX, 6 arg(s)
>> not ok 144 - MAX( 1., 2., 3., 4., 5.,Inf)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Double inf
>>        MAX, 6 arg(s)
>> not ok 145 - MAX( 1., 2., 3., 4.,Inf, 5.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Double inf
>>        Integer 5 (0x5)
>>        MAX, 6 arg(s)
>> not ok 146 - MAX( 1., 2., 3.,Inf, 5., 4.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double inf
>>        Integer 5 (0x5)
>>        Integer 4 (0x4)
>>        MAX, 6 arg(s)
>> not ok 147 - MAX( 1., 2.,Inf, 4., 5., 3.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double inf
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 3 (0x3)
>>        MAX, 6 arg(s)
>> not ok 148 - MAX( 1.,Inf, 3., 4., 5., 2.)
>>        Integer 1 (0x1)
>>        Double inf
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 2 (0x2)
>>        MAX, 6 arg(s)
>> not ok 149 - MAX(Inf, 2., 3., 4., 5., 1.)
>>        Double inf
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 1 (0x1)
>>        MAX, 6 arg(s)
>> not ok 156 - MIN(1.,-Inf)
>>        Integer 1 (0x1)
>>        Double inf
>>        UNARY_NEG
>>        MIN, 2 arg(s)
> This and some of the tests below imply that when the compiler does the math it's handling NaN as though it’s the value 1.79769e+308.
>> not ok 157 - MIN(1.,NaN)
>> # Expected result is 1, actually got nan
>>        Integer 1 (0x1)
>>        Double nan
>>        MIN, 2 arg(s)
> The expected result there ought to be NaN, not 1.
> Given the previous result though this test pass surprises me:
>> ok 158 - MIN(NaN,1.)
> The result of the above should have been NaN, but the compiler’s expected result would have been 1.0. Can you try adding this line to the epicsCalcTest.cpp file and see what it gives?
>>     testCalc("MIN(NaN,1.)", NaN);
> Compiler errors in the expected result:
>> not ok 166 - MIN( 1., 2.,-Inf)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double inf
>>        UNARY_NEG
>>        MIN, 3 arg(s)
>> not ok 167 - MIN( 1., 2., NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double nan
>>        MIN, 3 arg(s)
>> not ok 169 - MIN( 1.,-Inf,2.)
>>        Integer 1 (0x1)
>>        Double inf
>>        UNARY_NEG
>>        Integer 2 (0x2)
>>        MIN, 3 arg(s)
>> not ok 172 - MIN(-Inf, 1.,2.)
>>        Double inf
>>        UNARY_NEG
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        MIN, 3 arg(s)
>> not ok 178 - MIN( 1., 2., 3.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double nan
>>        MIN, 4 arg(s)
>> not ok 187 - MIN( 1., 2., 3., 4.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Double nan
>>        MIN, 5 arg(s)
>> not ok 198 - MIN( 1., 2., 3., 4., 5.,NaN)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Double nan
>>        MIN, 6 arg(s)
>> not ok 204 - MIN( 1., 2., 3., 4., 5.,-Inf)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Double inf
>>        UNARY_NEG
>>        MIN, 6 arg(s)
>> not ok 205 - MIN( 1., 2., 3., 4.,-Inf, 5.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Double inf
>>        UNARY_NEG
>>        Integer 5 (0x5)
>>        MIN, 6 arg(s)
>> not ok 206 - MIN( 1., 2., 3.,-Inf, 5., 4.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Double inf
>>        UNARY_NEG
>>        Integer 5 (0x5)
>>        Integer 4 (0x4)
>>        MIN, 6 arg(s)
>> not ok 207 - MIN( 1., 2.,-Inf, 4., 5., 3.)
>>        Integer 1 (0x1)
>>        Integer 2 (0x2)
>>        Double inf
>>        UNARY_NEG
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 3 (0x3)
>>        MIN, 6 arg(s)
>> not ok 208 - MIN( 1.,-Inf, 3., 4., 5., 2.)
>>        Integer 1 (0x1)
>>        Double inf
>>        UNARY_NEG
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 2 (0x2)
>>        MIN, 6 arg(s)
>> not ok 209 - MIN(-Inf, 2., 3., 4., 5., 1.)
>>        Double inf
>>        UNARY_NEG
>>        Integer 2 (0x2)
>>        Integer 3 (0x3)
>>        Integer 4 (0x4)
>>        Integer 5 (0x5)
>>        Integer 1 (0x1)
>>        MIN, 6 arg(s)
>> not ok 236 - Inf != NaN
>> # Expected result is 0, actually got 1
>>        Double inf
>>        Double nan
>>        NOT_EQ
> So the compiler thinks Inf == NaN?
>> not ok 242 - NaN != Inf
>>        Double nan
>>        Double inf
>>        NOT_EQ
> At least it’s consistent.
> These expected results are fun:
>> not ok 263 - Inf * Inf
>> # Expected result is 3.40282e+38, actually got 1.79769e+308
>>        Double inf
>>        Double inf
>>        MULT
>> not ok 264 - Inf * -Inf
>> # Expected result is -3.40282e+38, actually got -1.79769e+308
>>        Double inf
>>        Double inf
>>        UNARY_NEG
>>        MULT
>> not ok 265 - Inf * NaN
>>        Double inf
>>        Double nan
>>        MULT
>> not ok 267 - -Inf * Inf
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        MULT
>> not ok 268 - -Inf * -Inf
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        UNARY_NEG
>>        MULT
>> not ok 269 - -Inf * NaN
>>        Double inf
>>        UNARY_NEG
>>        Double nan
>>        MULT
>> not ok 271 - NaN * Inf
>>        Double nan
>>        Double inf
>>        MULT
>> not ok 272 - NaN * -Inf
>>        Double nan
>>        Double inf
>>        UNARY_NEG
>>        MULT
>> not ok 273 - NaN * NaN
>>        Double nan
>>        Double nan
>>        MULT
>> not ok 284 - Inf + Inf
>>        Double inf
>>        Double inf
>>        ADD
>> not ok 285 - Inf + -Inf
>>        Double inf
>>        Double inf
>>        UNARY_NEG
>>        ADD
>> not ok 286 - Inf + NaN
>>        Double inf
>>        Double nan
>>        ADD
>> not ok 288 - -Inf + Inf
>> # Expected result is 3.40282e+38, actually got -1.79769e+308
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        ADD
>> not ok 289 - -Inf + -Inf
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        UNARY_NEG
>>        ADD
>> not ok 290 - -Inf + NaN
>>        Double inf
>>        UNARY_NEG
>>        Double nan
>>        ADD
>> not ok 292 - NaN + Inf
>>        Double nan
>>        Double inf
>>        ADD
>> not ok 293 - NaN + -Inf
>>        Double nan
>>        Double inf
>>        UNARY_NEG
>>        ADD
>> not ok 294 - NaN + NaN
>>        Double nan
>>        Double nan
>>        ADD
>> not ok 301 - Inf - Inf
>>        Double inf
>>        Double inf
>>        SUB
>> not ok 302 - Inf - -Inf
>>        Double inf
>>        Double inf
>>        UNARY_NEG
>>        SUB
>> not ok 303 - Inf - NaN
>>        Double inf
>>        Double nan
>>        SUB
>> not ok 305 - -Inf - Inf
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        SUB
>> not ok 306 - -Inf - -Inf
>>        Double inf
>>        UNARY_NEG
>>        Double inf
>>        UNARY_NEG
>>        SUB
>> not ok 307 - -Inf - NaN
>>        Double inf
>>        UNARY_NEG
>>        Double nan
>>        SUB
>> not ok 309 - NaN - Inf
>>        Double nan
>>        Double inf
>>        SUB
>> not ok 310 - NaN - -Inf
>>        Double nan
>>        Double inf
>>        UNARY_NEG
>>        SUB
>> not ok 311 - NaN - NaN
>>        Double nan
>>        Double nan
>>        SUB
>> not ok 339 - Inf < NaN
>>        Double inf
>>        Double nan
>>        LESS_THAN
> Here the compiler’s expected result was actually right (confirmed on Darwin) and the actual result is wrong. Try adding this line to epicsCalcTest.cpp to confirm:
>>     testCalc("Inf < NaN", 0);
>> not ok 366 - NaN <= Inf
>>        Double nan
>>        Double inf
>>        LESS_OR_EQ
> Another surprise there, please try adding this:
>>     testCalc("NaN <= Inf", 0);
>> not ok 383 - Inf == NaN
>>        Double inf
>>        Double nan
>>        EQUAL
> Yes, the compiler does think Inf == NaN!
>> not ok 389 - NaN == Inf
>>        Double nan
>>        Double inf
>>        EQUAL
> Both ways round too!
>> not ok 408 - NaN > Inf
>>        Double nan
>>        Double inf
>>        GR_THAN
> The compiler is being consistent, but /any/ expression involving a NaN should return 0. Try this to confirm:
>>     testCalc("NaN > Inf", 0);
>> not ok 421 - Inf >= NaN
>>        Double inf
>>        Double nan
>>        GR_OR_EQ
> And this:
>>     testCalc("Inf >= NaN", 0);
> So there are problems in the compiler, but the run-time doesn’t seem to be 100% right either. The compiler issues should be easily extracted into simple C/C++ code and reported (to the RTEMS guys first?) if someone wants to work on that...
> - Andrew
> Complexity comes for free, simplicity you have to work for.
Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Arithmetic - test with qoriq Heinz Junkes via Core-talk
Prev: Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Next: Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 15 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
