2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Arithmetic - test with qoriq
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 15 Jan 2021 23:57:46 +0000
On Jan 15, 2021, at 1:00 PM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
On 1/15/21 10:49 AM, Johnson, Andrew N. via Core-talk wrote:
The above expected results were calculated by the compiler and are wrong, whereas the calc _expression_ is actually returning the right result.
From a quick look at math.h with RTEMS 5.1 i386 (really newlib?)
the INFINITY macro (used in epicsMath.cpp to initialize epicsINF)
should expand to a __builtin_inff().
This might have something to do with the PowerPC e500 family, which uses a different set of FP instructions to the older PPC603/604/MPC750 CPU cores (maybe SPE2?). I remember reading that to properly support the full IEEE floating-point standard the OS has to emulate certain operations. My guess is that RTEMS contains the correct code for doing that (which is why the calc engine is mostly getting the right answers), but the compiler isn’t being given the right flags to tell it to behave similarly.
It might be worth making sure this is used.  (as opposed to
our makeINF() in epicsMathc.cpp)  Also to see what the
builtin really is expanding to for this powerpc target.
Agreed, those makeINF() and makeNAN() functions are really only provided there as a last-resort, in most cases the OS-specific epicsMath.h should be making sure that INFINITY and NAN are properly defined from the platform-specific headers.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Arithmetic - test with qoriq Ralph Lange via Core-talk
Arithmetic - test with qoriq Heinz Junkes via Core-talk
Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Re: Arithmetic - test with qoriq Michael Davidsaver via Core-talk
Prev: Re: Arithmetic - test with qoriq Michael Davidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-125 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Arithmetic - test with qoriq Ralph Lange via Core-talk
ANJ, 18 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
