2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Arithmetic - test with qoriq
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 18 Jan 2021 10:08:54 +0100
On Sat, 16 Jan 2021 at 00:59, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
On Jan 15, 2021, at 1:00 PM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
On 1/15/21 10:49 AM, Johnson, Andrew N. via Core-talk wrote:
The above expected results were calculated by the compiler and are wrong, whereas the calc _expression_ is actually returning the right result.
From a quick look at math.h with RTEMS 5.1 i386 (really newlib?)
the INFINITY macro (used in epicsMath.cpp to initialize epicsINF)
should expand to a __builtin_inff().
This might have something to do with the PowerPC e500 family, which uses a different set of FP instructions to the older PPC603/604/MPC750 CPU cores (maybe SPE2?). I remember reading that to properly support the full IEEE floating-point standard the OS has to emulate certain operations. My guess is that RTEMS contains the correct code for doing that (which is why the calc engine is mostly getting the right answers), but the compiler isn’t being given the right flags to tell it to behave similarly.
The different FP standard is what's mentioned in the Tech-Talk message I was pointing to in my first comment.
My idea of how this affected the issue was drastically wrong, though.
~Ralph
Arithmetic - test with qoriq Heinz Junkes via Core-talk
Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Re: Arithmetic - test with qoriq Michael Davidsaver via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #914 Jenkins EPICS PSI via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #915 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Arithmetic - test with qoriq Johnson, Andrew N. via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-125 AppVeyor via Core-talk
ANJ, 18 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
