2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Tue, 02 Feb 2021 08:34:27 -0000
The failing MacOS compilation have this error:
  ../epicsMutexPriorityInversionTest.c:19:54: error: function-like macro '__GLIBC_PREREQ' is not defined
  #if defined(__GLIBC__) && defined(__GLIBC_PREREQ) && __GLIBC_PREREQ(2,4)
It first tests that __GLIBC_PREREQ is defined and then caomplains that it is not defined?
Is it defined as a non-function-like macro on that platform?
The RTEMS compilations fail in the same line but with another error:
  ../epicsMutexPriorityInversionTest.c:19:68: error: missing binary operator before token "("
Again, it seems to have problems with __GLIBC_PREREQ.
The C Processor manual says that && and || "obey the usual short-circuiting rules of standard C." Thus __GLIBC_PREREQ(2,4) should never be evalueted if __GLIBC_PREREQ is not defined.
Anyway, I will try to fix this...
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 02 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
