2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: RT linux and priorities
From: "Konrad, Martin via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 2 Feb 2021 19:48:23 +0000
Hi Michael,
> It looks like the ISR threads default to SCHED_FIFO/50, which is also what
> epicsThreadPriorityMedium currently maps to.  So eg. the 1 second scan task
> has a higher priority (63) than the NIC ISR thread (50).  This seems like
> a recipe for some unexpected priority inversions.
Looking at the output of your "ps" command the header of the first two
columns say "RTPRIO" and "PRI" (in this order). It seems like you are
comparing numbers in the "PRI" column. The man page of "ps" says:
pri         PRI       priority of the process.  Higher number means
                      lower priority.
If I understand that correctly 63 would mean _lower_ priority than _50_.
I'm not sure if the fact that SCHED_RR is active changes the meaning of
these numbers.
> Now I'm also wondering how firefox is able to set SCHED_RR/10
Hmm, IIRC setting SCHED_RR requires elevated privileges. Maybe you have
granted a parent process (or possibly even PID 1) elevated permissions?
If your machine is using systemd you might want to run
grep -ri rtprio /etc/systemd/
to check. "ulimit -r" might also provide some insight.
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: konrad at frib.msu.edu
Re: RT linux and priorities Michael Davidsaver via Core-talk
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Andrew Johnson via Core-talk
Next: Re: RT linux and priorities Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: RT linux and priorities Michael Davidsaver via Core-talk
ANJ, 02 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
